Finally put some new wheels on my Formula... Ronal R15s inside!
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
One of the last things to be done... Car is getting a 9" installed this year along with getting painted.
Here is a bad quality teaser! Tires are 275/40r17 all around. I had to run a 5/16" spacer, and special lug nuts up front. Along with some grinding to the front struts/tie rods. Rear wheels fit without any modifications. Car is on Tokico Illuminas with matching drop springs.
I am hoping the suspension will settle another .5" or so...
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: Finally put some new wheels on my Formula... Ronal R15s inside!
sweet!!! always like the lip on these wheels
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
What special lug nuts? To compensate for the shorter bolts on the stock disks?
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Looks awesome! There is a 91/92 Z28 with them in my town and evertime I see the wheels I smile-that is the perfect 3rd gen wheel.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Car: 1987 Camaro LT
I'm going to have to do that so I can install the correct spacer in. The tire shop didn't have the longer bolts.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Yeah, I only did it as a temp thing because I am going to be Vette brakes up front and wont need the spacers after I put them on. I did put about 2k miles on that setup in 3 weeks though without any issues.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I picked them up off ebay for a STEAL. Guy listed them funny so there weren't any bids. I pick them up without tires for $760 shipped, with the windows already painted to charcoal
Car: '85 Z28
Car: 1987 Camaro LT
Are you enjoying how your car drives with the R15's? Took me a bit to get used to going from P195/70R14's to P275/40R17's
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Ride wise they are nice... Less tire roll is awesome. I also installed my drop suspension at the same time, so it rode much nicer than when it had the prokit with blown front struts.
Car: 1987 Camaro LT
I decided not to lower it but going to look for the longer bolts before I install the 1LE brakes which I have ready to go. But in the mean time, I just want that tire rub to stop due to the incorrect spacer.
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Looks great, hope you enjoy them as much as I have on my car. As said above, they seem to be the perfect third gen wheel. Pontiac/SLP nailed it when these were original equipment on '92 Firehawks.
I still get compliments on mine.
Car: 1987 Camaro LT
Here's some pics of mine.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Here are some more! Didn't get a whole lot of pictures when I was home, I was too busy driving it and enjoying life!
On my way to Oregon
Mini 3rd gen GTG in Sacramento
On my way to Oregon
92camaroJoe
Aug 13, 2015 06:07 AM
wow nice
