Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Looking for a t-56 setup
Old Nov 28, 2004 | 05:58 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
does anyone know about how much it owuld cost for everythign i need for the t56 swap and does neone have one for sale im not having much luck aorund here
Old Nov 29, 2004 | 12:55 AM
Kandied91z's Avatar
15-2000 usually when all is said and done.
Old Nov 29, 2004 | 01:54 PM
Car: 87 Formula
Engine: 350 tpi
wow is that for a used one?!? man this is becoming more and more un affordable
Old Nov 29, 2004 | 03:15 PM
pskel350's Avatar
you might get lucky and find a setup for just over grand, but i would have 2k in your pocket if you want to do it right the first time.....
Old Nov 29, 2004 | 04:26 PM
Kandied91z's Avatar
just replace it with realistic parts then like another t-5 or even a cheap 700-r4.
Old Nov 29, 2004 | 05:37 PM
Car: 87 Formula
Engine: 350 tpi
defintily not goin to an auto lol but im tryin to get the driveline built up to accpet the motor im working on i emailer tko performance but im nto sure i have a w/c t-5 if not where would be a good place to find a t-5 that im 100% sure is a w/c
Old Nov 29, 2004 | 06:13 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
my friend just picked up two t-56 transmissions. one was given to him because his friend didnt need it and the other he picked up for $300
Old Dec 1, 2004 | 01:02 AM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
Denny has one for sale, check the classifieds. It's $1750 I think.
Old Dec 1, 2004 | 09:19 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
If the T-5 you have is original, it should be a WC. Otherwise, you need to look at original T-5's from 88-92.
Even a stock T-5 can hold up for quite a while so long as you don't beat on it (i.e. speed shift or run slicks)....
Old Dec 1, 2004 | 01:44 PM
Car: 87 Formula
Engine: 350 tpi
that what i thought but someone told me w/c were optins 88-90 then standard 91-92 its the stock transmission so does that mean itsa w/c?
Old Dec 1, 2004 | 05:22 PM
Confuzed1's Avatar
Car: 83Z28 HO
AFAIK, there was no option as to which 5 speed you got between 88-90.
I've always heard that all T-5's between 88-92 were WC, and those before were the NWC BW type. There should be a metal tag on one of the casing split line bolts on your trans.
Get the numbers off that and look it up on Gearzone.net (I think) and they have a chart that tells you what you have.
Old Dec 1, 2004 | 06:01 PM
Car: 87 Formula
Engine: 350 tpi
ok thanks alot guys looks like my t-5 is gettin sent to tko for a lil upgrade lol i reall appericiate all the help
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
