Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
ANY GEARHEADS FROM ST PAUL AREA LOOKIN TO MAKE FEW BUCKS?
Old 10-04-2010, 03:46 PM
zachkuby87's Avatar
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
I just rebuilt the top end of my 350 for my camaro and can't get it to run i would be willing to pay up to 150 bucks if someone can come help me diagnose the problem and get the car running its a 350 bored.30 rhs pro action heads comp cams 292 magnum edelbrock performer intake and a holley 750 vacuum advance it turns over the most I can get is a backfire I've moved the distributor 50 times at least and can't get anything my next step is checking the timing chain cause I replaced it and it was my first build so I don't know. If anyone has time and might wanna make a few bucks it would b awesome to get the car running and be able to go for a cruise or two before winter thanks.... reply or pm me ad we can figure someting out
Old 10-04-2010, 06:30 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: ANY GEARHEADS FROM ST PAUL AREA LOOKIN TO MAKE FEW BUCKS?
if only you were near chicago, i'd look at it for a case of beer one evening
Old 10-04-2010, 10:38 PM
zachkuby87's Avatar
Car: 1985 iroc z
Transmission: t-5
I would gladly buy u a case of beer hell I would even give you another case for the road
Old 10-04-2010, 11:19 PM
xpndbl3's Avatar
Car: 1984 Z28
pop off the drivers valve cover, spin the motor over by hand until you see the #1 exhaust open and close, then the #1 intake valve open and close, continue turning it until the balancer mark lines up with 10 degrees before the zero reading on the timing tab. Mark your distributor where the #1 wire goes with a black sharpie on the housing below where the cap mounts. Pop the cap off, is the rotor pointing at this mark? If not turn it until it is. Pop the cap back on and try to start it, you may need to advance the distributor slightly to get it fire up before checking timing. To advance it you could turn it slightly clockwise looking from the front of the car.
Hope this helps.
Old 10-07-2010, 09:29 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Where in st paul are you? I may be able to come by and give you a hand soon.
Old 10-07-2010, 03:00 PM
zachkuby87's Avatar
Car: 1985 iroc z
Transmission: t-5
I'm in st paul off larpenteur avenue... I'm pretty sure I've narrowed the problem down to a timing issue my problem is I don't have a lot of tools or know how to get everything right all I have are basic hand tools and not very many at that...
Old 10-08-2010, 07:11 AM
dellman83Z's Avatar
I've got some plans this weekend, but I will PM you my number and we can arrange a time to try to figure it out.
Old 10-26-2010, 09:26 PM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
I just saw your post now, but I would be willing to give you a hand. PM me and let me know if you still need help.
Old 10-26-2010, 10:07 PM
zachkuby87's Avatar
Car: 1985 iroc z
Transmission: t-5
Cars still not running and as you know this garbage weather isn't helping much
Old 10-26-2010, 10:16 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Go over to mngmp.org
Make a post in the "Emergency Help" section for the best response.
There's few from St. Paul that might stop by to help. Probably not tonight with this weather though. lol
Did you double check the firing order? I know it sounds simple but sometimes it's easy to get a couple wires mixed up.
CarGuyDennis
137
12-06-2016 11:02 PM
thefirebirdm@n
South Central Region
09-14-2015 01:45 PM
NWAsonoma
08-18-2015 05:45 PM
st.evel07
08-13-2015 06:15 PM
Street Lethal
08-12-2015 11:33 AM
Quick Reply: ANY GEARHEADS FROM ST PAUL AREA LOOKIN TO MAKE FEW BUCKS?
