Registering a modified vehicle in NJ?
Car: 92 RS
Transmission: 7R4
Anybody live in NJ and have an engine swapped third gen which is legally registered and insured?
What was the process? Did you register it as anything special?
My check engine light is on, and may always be. The stupid DMV fails cars for that, so how to deal with this issue? (don't say cut bulb out, fail for that too.)
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Registering a modified vehicle in NJ?
what are you looking for in terms of inspection? a standard drive 10 million miles a year inspection? or a limited use inspection?
the old loophole used to be collector vehicle registration. there is no emissions check at the station, but you are limited to 3k miles a year. As of last year you have to prove the car is rare or collectible to get this inspection, it requires info being sent in from a car group or agency verifying that the car is a collectors item.
Aside from that, you cant put an older motor into a newer car. If the car was fuel injected, you cant use a carb.
If the cam is not too radical, the car has all the emissions equipment intact and it passes the sniffer, your fine. If its something else, i dont know.
I guess the biggest question is what did you swap from/to
Im currently using the collectors registration, but as of last year, its a lot harder to get. I have to have mine renewed in January.
As for the check engine buld, seriously, take the bulb out if thats what it takes. They dont scan the computer of the older cars to the best of my knowledge. If you pass, put it back in or just leave it out.
Car: 92 RS
Transmission: 7R4
1986 Z28 305 4bbl to 87-88 carbureted GM Crate 350. Car has catalytic converter in place.
do you still have all the emmission parts on the motor? air pump and injection? You may be able to pass as it is. Worth a shot anyway.
Car: 92 RS
Transmission: 7R4
Just a motor w/ alternator, shorty headers etc.
Some how the guy before me passed the sticker is good until 2/2010 but the paperwork is from a private facility, so I'm thinking he knew somebody.
So when I go to register the vehicle, all I do is register it like a normal car then and worry about "knowing somebody" for inspection down the road i guess.
without the emission equipment, your going to have to know somebody who doesnt care about their inspectors licence. Its possible they swapped the motor after they had the car inspected.
Car: 92 RS
Transmission: 7R4
The emissions portion of the test says:
nox 1046 actual 33
hc 140 actual 31
co% 0.79 actual 0.15
c02% actual 15.0
0² actual 0.0
RPM actual 1430
I mean, that's a clean running car if that was actually done on this car? you think its possible?
nox 1046 actual 33
hc 140 actual 31
c02% actual 15.0
0² actual 0.0
RPM actual 1430
anything is possible, but like i said, the motor could have been swapped AFTER that test was performed.
You might pass flying colors, i know a few 4th gen guys who have passed the NJ sniffer test with no cats.
I think the issue would be the visual inspection, if the station cares to check under the hood. I say go for it and see what happens.
Car: 92 RS
Transmission: 7R4
Engine was said to be swapped 5 yrs ago, but thanks for the advice man I will have to cross that bridge when i get to it I guess.
Car: 87 Trans Am
Engine: L98 350 w/carb
Transmission: TH350
That check engine light is a problem too. As long as thats on they'll never pas s you no matter how clean your running. So you'll have to do exactly what you said earlier and find someone who would pass it. But the fines pretty big I hear it's 10k now and there inspection license can get pulled so it's not gonna be easy.
Car: 87 Trans Am
Transmission: TH350
Yeah I currently have the same inspection problem I have a car that was originally 305 ccquadrajet and now its got a 350 with an old style carb set up and dual exhaust w/ no cats idk where i'm gonna get it inspected.
