MA emissions...I need a good answer
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Hello, I have never really gotten a good complete answer on this.
What exactly does MA test? I have an 86z28. Do they do visuals?
an even better answer would be..
what can I take out of my engine bay?!
I really appreciate it!
-Andrew
-Andrew
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: MA emissions...I need a good answer
remove? nothing emmissions related. You can remove the A/c is you so desire.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
wow another Mass hole, 95 or older vehicles dont pass emissions anymore the mass 31 test is gone since october. My 83 T/A they only checked for safety, I would not remove the smog pumpAir unless i know the owner of a shop who would pass me. plus the cops dont know what a smog pump is unless they owned a third gen
Even if they do just say GM discontinued it and is with holding the licenseing rights.
Even if they do just say GM discontinued it and is with holding the licenseing rights. Last edited by KITT1983; Jan 18, 2009 at 09:32 AM.
-Andrew
http://www.northeastshooters.com/vbu...ad.php?t=47177
http://www.mass.gov/rmv/faq/inspection.htm
http://www.mass.gov/rmv/faq/inspection.htm#10
1972 Oldsmobile failed for emissions when back in 1972 there were no emissions components on cars other than a PCV valve wow the guy who did test was an idiot. Vehicles were not tested for emissions until the 1975 model year when they first equipped cars with the dreaded catalytic converter.
Sweet man, thanks. So this is what im getting out of this... The only thing that we have to worry about now is safety things, and smoke coming out of the exhaust? I like to be very sure of things, so I don't mess anything up. And I might as well leave in the smog pump..and was this just a typo? "smog pumpAir" or was there a second thing as well?
Thank you!
-Andrew
Thank you!
-Andrew
Remove the Smog Pump/A.I.R. system, (it is one whole unit) it won’t make a difference and the catalytic converter too. The mechanic who failed that 1972 Oldsmobile needs to go back to school or have a drug test done because that car had no emission parts and it could never be tested for emissions. Unless your car is burning coolant or oil you should not fail.
What part of Massachusetts are you from?
ok sweet, thanks man I really appreciate it. I am from Hanson, if your familiar. If not its about 45 mins south of Boston, west of Plymouth kind of. If you know Hanover because of the mall, its the next town over.
Car: 87 IROC Z, 2010 2LT
Engine: 305 TPI, 3.6 V6
Transmission: 5-Spd, 6-Spd
Axle/Gears: G92 3.45
really? you can remove the cat and they won't give ya hell for it if it's pre-95?? If that's the case, that kicks ***.
any updates
Ayup. They didn't even open the hood or look under the car aside from checking the ball joints. All good
Thornburg
Aug 25, 2015 01:46 AM
