Northern California Discussion board for Northern and Central California.
test~n~tune March 5
Old Mar 9, 2005 | 01:25 AM
  #151
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Wow, great discussion guys, not that I didn't understand anything.
Anyway, Eric, when do you plan on having the tranny fixed? Are you going to do it yourself?
Terrell, sorry to hear about the troubles, what do you plan on doing to fix the problems? Even if it's slow, at least you will be driving your thirdgen again. I know how you feel about that.
Old Mar 9, 2005 | 01:37 AM
  #152
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
used motor(not sure on displacement) with new gaskets and maybe rings and bearings no machine work or anything like that to cut down on cost
Old Mar 9, 2005 | 02:08 PM
  #153
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Originally posted by adambros
ok, ok -- I believe ya
- but the point I was trying to make originally was that just becuase you are in open loop and your BLM's are reading at 128, does not mean your not running rich / lean.
point taken.... but i dont think i am i believe my problem is i fried these injectors which didnt work too good anyway, downlow i get a slight misfire until about 2500, the injectors work pefrect at wot for a reason its easy for them its just an open signal, how ever that is what is causing my rich problem, with the misfire releasing extra o2 in the exhaust the o2 sensor sees that oxygen and tries to richen it up, too bad there isnt a fuel oxygen sensor hahaha
Old Mar 9, 2005 | 06:57 PM
  #154
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
wouldnt it just be called a fuel sensor?
Old Mar 9, 2005 | 09:08 PM
  #155
porkyzilla's Avatar
Engine: 5.7tpi 350,
no i was making a joke saying that would be cool if it was a combined sensor.. that could sense fuel, and o2
Old Mar 9, 2005 | 10:08 PM
  #156
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
that would actually work, but theirs different gas's in the exhaust, which one would it read? nox? it should have a sensor for o2 and nox, and give you the avg of the two in a digital or analogue gauge ranging from like 8-18 of coarse 14.7:1 being optimum
Old Mar 10, 2005 | 01:30 AM
  #157
Car: 07 Silverado
Nice, nothing wrong with not doing the machine work now. I bought my GM crate motor bone stock and didn't touch it. I don't plan on doing any machining to it until I can afford to also put in a nice cam. Anyway, hope to see your car back on the road soon.
Old Mar 10, 2005 | 01:29 PM
  #158
porkyzilla's Avatar
Engine: 5.7tpi 350,
guys i had to get my exhaust welded shut today it sounds like well crap
its so quiet i can hear my intake over my exhaust
now to get it to pass smog wish me luck ima throw it on the dyno today
Old Mar 10, 2005 | 01:32 PM
  #159
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Good luck - Im takin' my bird in tomorrow for a pre-test. Definately don't wanna get flagged as a gross polluter.
Old Mar 11, 2005 | 01:19 AM
  #160
Car: 07 Silverado
Eric, I may be in this weekend to Bennie's shop for my car getting smoged also. It's due by April 12. Not worried about it passing except for the visual gas leaks by the tank, which is all good because I want those fixed anyway. Would have done it already, but I need the car on a lift to get to the leaks.
Old Mar 11, 2005 | 01:28 AM
  #161
porkyzilla's Avatar
Engine: 5.7tpi 350,
ill hook you guys up... if you wanna bring it to the shop
916-974-7664
for those of you who need it and what do you know my car is getting smogged too... from a prev- gross polluter i gotta go to test only though maybe ill go wearing my work shirt
Old Mar 11, 2005 | 02:00 AM
  #162
Car: 07 Silverado
Hell yes Eric, hook me up if it's all good with Bennie of course. I should be there early Saturday, or is there a specific time I should come? Let me know, thanks.
Old Mar 12, 2005 | 08:15 PM
  #163
porkyzilla's Avatar
Engine: 5.7tpi 350,
https://www.thirdgen.org/techbb2/sho...hreadid=283730
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
eustodp
Sep 20, 2015 05:09 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
