Northern California Discussion board for Northern and Central California.
Only $1000 till...
Old Oct 23, 2005 | 05:50 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Only $1000 till...
....my engine gets rebuilt with a partially forged bottom end and an LE1 cam (link) with mid 230's duration on both sides and 530/540s lift loping on a 110 or 112 LSA - depending on what I choose. Unfortunatly I don't know the exact specs yet but I'll have them soon.
I can't do the heads right now, but they'll get done eventually. I'll probably add long tubes when I pull the motor. Want to sell yours seperately kyle??
I'll be using a Fed Mogul rebuild kit with forged aluminum pistons The rods and crank will be stock pieces. The kit is $539 through summit, although I might get a better deal through my shop.
Judging by other people's LT1s, this cam alone should put me in the mid 12s with traction and headers. When I get the heads, it runs 11s.
Need to work about 3 more weeks to get the cash
Also need a new posi unit.. mine is dying Can anyone say full spool???
Old Oct 23, 2005 | 08:25 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
Re: Only $1000 till...
rob a bank *****
Old Oct 24, 2005 | 01:29 PM
Car: '72 Chevy Nova
Transmission: TH350
Re: Re: Only $1000 till...
Originally posted by 3.492rs
rob a bank *****
I don't know about a bank, but I might start knocking off gas stations and mugging people...
Old Oct 24, 2005 | 02:36 PM
r1maniac's Avatar
Car: 2006 yamaha r1 50th anniversary
Engine: 1.0 ;)
i would tony but nobody bite when i wanted to sell them so now the car is going to sit until its paid off and then iam going to call lloyd elliot and have him custom grind me a cam thats bigger than the le3 cam around 240-250 duration at .050 and i have to do a automatic swap and hellow low11s i hope
Old Oct 24, 2005 | 03:12 PM
Car: '72 Chevy Nova
Transmission: TH350
yeah i remember you telling me about that.. I don't suppose you'd be interested in a straight up my A4 for your M6 swap would you?? I'd rip my tranny in a heartbeat But something tells me you'll be going with a TH350 or 400.. Let me know when you pull your T56, I'll most likely buy it.
Old Oct 24, 2005 | 03:30 PM
r1maniac's Avatar
Engine: 1.0 ;)
yeah i want a th350 but you dont want my tranny anyway its a piece of **** it would have to be rebuilt to hold the power your going to be putting down if you dont have a tranny when i do the swap you can have the piece of crap
Old Oct 24, 2005 | 08:00 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Don't forget the fun factor downgrade swap kracka!
Tony, why would you want a Manual trans also
You would lose that little "Performance" button for christ sake!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That's at least 50hp lost!
Kyle you should sell your trans to a guy who already has a stick and needs a swap, like Vin
Old Oct 24, 2005 | 08:55 PM
Car: '72 Chevy Nova
Transmission: TH350
That would be awesome man, no biggie on rebuilding it. I got da hookup.
And I want to swap to a manual just because it's funner to drive. And I can put a more useful button in that performance button spot... like a nitrous switch..
db057
Jan 10, 2020 08:55 PM
PurelyPMD
May 5, 2016 04:57 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
AussieZ28
Sep 30, 2015 03:36 PM
