Northern California Discussion board for Northern and Central California.
High Volume oil pump ???
Old Feb 1, 2006 | 01:55 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Im startin my buildup of a 355 sbc motor with Vortec Heads on a Tpi fuel injection system... what is needed if I go to a high volume oil pump (i.e. bigger oil pan, etc)? will I have any lubricating issues if I stay with a standard volume pump? Please help
Old Feb 1, 2006 | 06:29 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
no problem really, except farther down the road u may have more leaks.
Old Feb 1, 2006 | 09:07 PM
Copchaser's Avatar
Why do u say that?
Old Feb 1, 2006 | 09:15 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i dont know, just what ive heard, i guess high pressure on old seals doesnt work well.
Old Feb 1, 2006 | 10:24 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
you can use a high volume pump, but it's not necessary unless you're planning on sustained high-speed cornering (Autocross, circle track, road course). A high volume pump can actually work against you in some situations. For a street/strip motor I'd recommend a normal pump.
Old Feb 1, 2006 | 10:50 PM
Copchaser's Avatar
thanks for the info.. I appreciate it. I was concerned with gettin a new oil pan and making modifications to have the exhaust fit properly and other garbage.. But your tips helped... thank u
Old Feb 1, 2006 | 10:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yes, we rule.
Old Feb 2, 2006 | 03:18 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I have a HV Melling Oil Pump with my stock oil pan and couldn't be happier, I love starting my car and watching the Oil Psi get pegged.
You don't really need an aftermarket pan with more capacity unless you want to bee cool like Mr. 3.485670246957RS and have your y-pipe slapping against it.
And as mentioned earlier make sure that all your gaskets are in good shape, not much of a problem if your timing cover is sealed well IMHO, we already have 1 pc oil pan gaskets.
Old Feb 2, 2006 | 04:17 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
so vin, i am cool with my advanced oiling system.
Old Feb 2, 2006 | 07:30 PM
JesasaurusRex's Avatar
check ur PM's bish
Old Feb 4, 2006 | 10:30 AM
Copchaser's Avatar
the pump isnt too long for the pan or anything? I thank u guys for the reassurance of reliability. Thanks guys... stay tuned as the build up continues...THE CHASER
Old Feb 4, 2006 | 10:39 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Should be the same external dimensions as a stock pump....Just differant guts.
Jason
Old Feb 6, 2006 | 10:05 PM
ratrodjon's Avatar
Car: 89 CAMARO, GUTLESS WONDER
Engine: 305 TBI
Some pumps come with pickup tubes welded to housing, if yours doesnt have someone put a couple tack welds on it. Something common on sbc oilpumps, allthough ive never had it happen to me, ive heard that they can come out as they are press fit.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
BBSDesigns
Aug 11, 2015 07:39 PM
