Northern California Discussion board for Northern and Central California.
push button
Old Aug 20, 2006 | 01:42 AM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
push button
after a few long hours... my car officially uses a push button starter!
Old Aug 20, 2006 | 04:35 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
A few hours? Did you build the push button switch factory also?
j/k Ron
Old Aug 20, 2006 | 04:59 AM
j/k Ron
no but i did have to replace that damn eyelet on that wire you broke the first time lol
Old Aug 20, 2006 | 05:57 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Well if it would have came quietly there wouldn't have been a problem...
Plus someone was busy taking the Browns to the Superbowl anyways LOL
Old Aug 20, 2006 | 10:25 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
any pics? what all did you do? Still have to put then key in, but just push the start button? Or did you rig up something kinda like the newer cars?
Old Aug 20, 2006 | 04:10 PM
no, no pics, not gonna post any because its in a discrete location. i dont have the know how to do something like the newer cars, so it only works when the keys on ignition. the button can crank the starter, but it wont fire up unless the keys on.
Old Aug 20, 2006 | 04:11 PM
it was the damn mcd's
its like instant fiber as soon as you eat it.
Old Aug 29, 2006 | 05:19 AM
as for rough step by step....
materials=
(2) [if sold in packs] 12 gauge wire (12awg) different color for each wire
(1) push button switch, make sure its an OFF-ON-OFF switch, not a OFF-ON switch. this shouldnt be an issue if its a Starter Switch
(1) in-line fuse for the 12V
(1) 30amp fuse
and your choice of wire connectors, butts, quick splices etc...
find a good, hard to reach location for your button. why hard to reach? so that you wont hit it accidentally while driving.
once you decide on that pick a suitable sized push button switch.
i chose a 60amp switch, but i think 30amp should suffice
always disconnect your battery!!
remove whatever paneling you need to to mount your switch, run your wiring... drill if necessary...
i ran one 12awg wire directly to the battery with the fuse in line, since i have a battery post terminal for audio accesories.
the second 12awg wire goes to your starter solenoid on the S terminal
then run each one of these wires to either side of the switch.... one wire per screw, dummie.
connect your battery... test that baby out. if alls good... NOW mount your switch and check for flaws, loose screws etc. and voila all done, simple, and CHEAP! only cost me 15 bucks. and i dont know jack about electrical!!
this will work great for those of you who experience heat soak from hot uncoated or unwrapped headers. which is what i was experiencing. later down the line i will be wrapping my starter to preserve its longevity. ok thats all folks!
oh and be kind, its 3am -_-
Old Sep 6, 2006 | 01:09 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
hmm I've been thinking today about doing something like that, because of this problem
https://www.thirdgen.org/forums/tech...tart-died.html
Old Sep 7, 2006 | 02:23 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: push button start...
If you had to do it over again, would you? And if so, would you change anything?
Nitro
Old Sep 7, 2006 | 03:43 AM
Nitro
yeah i would
it was simple enough to do, considering i have only slight, basic electrical knowledge. and the coolness factor of starting your car with a push button doesnt wear out for a while
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
92projectcamaro
Sep 29, 2015 07:07 PM
