2014 car resolution
Engine: gone
Transmission: gone
Axle/Gears: gone
2014 car resolution
What are you going to get done on your car this year? Something you've been procrastinating on. Been wanting to do etc...
I am gonna get the rest of my parts needed for my motor. Gonna rering my block. install some new heads. install my 4bbl tbi. get her all tuned out. and get a run down the 1/4 mile this year. And gonna pick up some nice seats for the car. and get a nice tubular torque arm
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 2014 car resolution
where's your car resolution Joey? You can put to make one pass on it in March 2014 and then leave her for 2 years with Anthony so he can make sure she says in tip top running condition for when I return........if you'd like
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my resolution is to sell/partout the thirdgen and get into another vehicle that can be enjoyed and not fixed weekly.
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
My plans are all new from suspension ! Tubular everything ! Hopefully that will fix my squeaks and pops and unwanted noises coming from the front end also some new strut towers and a ST brace ... Then a N2O kit (100 shot plate).... And try to get my suspension in the rear tuned for the track ... Along with lots of Ebl tuning
Engine: gone
Transmission: gone
Axle/Gears: gone
sounds like a bunch of work! enjoy!
1 Post
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Going to bore the 350 .030 have pistons and rods ready to go put in my zz4 cam install vette 113 heads bolt on superram and install slp totl exhaust just to name a few
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Im going back to school. Im not going to have time to finish, so its all for sale.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
200 shot of NOS for the march drag day
....and you wish Anthony! lol
Engine: 383/LGX
almost got my lift set up...til the last dang stud pulled out (wedge type) and now there's a hairline crack where the baseplate is. Looks to be running into the control joint (guess that's why they tell you not to place them near those things) . Oh well, guess i'll get to pouring a new slab eventually Tired of not having my car to play with
Hey Vinny! Haha that's what I thought too every time I heard of somebody having one. Truth be told they're probably cheaper than most people think. It's really more about having the room in your garage than it is cost of the unit. Barely fit, and it's the short model. Went between the rafters on the one side, put a picture of that up later when I'm on the comp. Anyhoo, tell Mike hi if you still keep in touch. Ttyl
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
The same long list as last year. And the year before that and so on. Might at least start with battery relocation. Can't be hard. Can it?
Mine is not too lofty a goal. I resolve to DRIVE my car this year, come hell or high water. Not just talk about it and throw more money into it.
Install 140mph speedo with new cable, fix tach, modify Y pipe and fix some rust.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Dang, all sorts of action going on in here!
Must be the generic title opening up to all thirdgen.org posters.
What are you going back to school for Terrell?
If you're local still I may be into a couple parts.
The end of a very long 3rd gen dream for you!
Engine: 383/LGX
Looking into a couple different things, but for starters get my Associates Degree. Im still local and definitely not the end, just a pause.
Engine: gone
Transmission: gone
Axle/Gears: gone
okay yeah i have the 12k bendpak with the cables on the floor because previous shop roof wasn't high enough for overhead cables unfortunately.
For me, it's to get the Turbo and a Cam in the Iroc and also get some paint on her. Maybe I'll run the Nitrous for a while. Also to get my girl's Iroc running this month.
Gonna start a few small mods on my stock 5 speed LB9 G92 Iroc. Have SLP headers I recently picked up re-ceramic coated. Install headers with locking stage 8 bolts and Earl's reinforced ring header gasket. Purchase and install new 8mm Taylor wires with wire protectors. Wire up a heated o2 sensor in my header bung from a separate added mini fuse box. Install aluminum third gen GM driveshaft. New tires. Get a chip from Tuned Performance that will advance spark timing and what ever else he suggests that will free up some ponies. Install new console lid and replace plastic upper door moldings with the good ones I've had sitting in my room for about 2 years now lol. Change rear differential fluid. If I can get all that done by the end of 2014 I will be a happy camper. Then I will worry about saving for paint and interior.
Linson
08-21-2015 02:12 PM
