NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Need local help with code 34 problem
Old Aug 14, 2004 | 07:15 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I currently have a code 34 problem with my car for six weeks now. I cannot figure it. Have replaced the MAF, Computer, MAF power relay, and burnoff relay all with no sucess and have checked every vaccum line and gasket on the car.
The car is now totally unreilable and totally useless. So I have a car with a $5,000 paint job that does not run.
Does anyone local have a scanner or willing to lend a hand. I am also willing to take it to a mechanic. Can anyone recommend one?
Car- 88 IROC 305 TPI
I live in Hoffman Estates, IL (near Schaumburg)
Someone please help!!
Thanks,
Brian
brians133@hotmail.com
Pic here are pics of the car.
https://home.comcast.net/~brians133/
Old Aug 14, 2004 | 07:24 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
Is it drivable??? If you can get it to villa park I have a snap on scanner we can hook up...
Old Aug 14, 2004 | 07:30 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
And if you can't figure it out, I know a really good shop in Villa Park that I'm sure could help ya out. If my car is running by the time you decide to do that, I could give ya a ride back home
Not to assume you're stupid or anything, but have you cleared the codes by disconnecting the battery since you replaced the relays? I had a code 34 after I ran a few days with my MAF unplugged. It was still having trouble even after I plugged it back in until I disconnected the battery to clear the codes in memory..
Old Aug 14, 2004 | 07:48 PM
burnout88's Avatar
Car: 88 IROC
Thanks for the replies!!!
Yes, it is driveable, but it contastly stalls when at idle, the longer I drive it the worse it runs. But I can definetly make it to Villa Park.
camaro_60181 Do you have any time tomorow? If not whens a good time for you?
Also, I have definetly reset the computer and cleared the codes. Actually, After I do a reset it runs fine for about one hour's worth of driving and then all the problems come right back.
I really appreicate everyone's help!!!
Brian
(847)224-7110
Old Aug 14, 2004 | 08:56 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I had a similar problem as you, however when my SES light came on the car had no change in idle or performance. Yet, I got a code 34 just like you.
The wireing to my MAF burn off relay was all corroded and nasty. I have a "bucket o' harness" if you need some connectors off it. Can't gaurentee what you need is in there, but the offer is open.
Old Aug 15, 2004 | 01:01 PM
burnout88's Avatar
Car: 88 IROC
I am heading over to camaro_60181's place to do a scan today. Fruity 1, I may take you up on your offer since it does seem to be a problem in the loom or on a connector.
When you changed connector on the Burnoff relay did that solve your problem?
Thanks,
Old Aug 15, 2004 | 05:51 PM
FruityOne's Avatar
Yeah, I also did a great deal more when I did that.
EGR, 02, MAF, umm........lots of things
Then I took it all apart and put a ported TPI setup on there with heads, cam, and headers.
Old Aug 16, 2004 | 02:11 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Was the MAF new that you put in? Buddy had the same problem with his TPI 'Vette and someone mentioned to us to change the coolant temp sensor for the ECM and possibly fuel pressure regulator. We did both(they were cheap) and no more code 34. From what we figured, the temp sensor was giving an inaccurate reading to the ECM causing the MAF to also be inaccurate.
Nice car BTW!
Old Aug 19, 2004 | 11:53 PM
Guest
Guest
Posts: n/a
-=Jumps around in joy=-
when my car does that all i have to do is play with my carb and it will be fixed in about 10mins
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
