Pics of the new engine
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Well I figured after all the teasing and anticipation on my now track and car show only car. Here she is. Thank you for all your help guys and thank you Bob for doing awesome work.
http://ityberius.com/cars/camaro/jakescar/motor.htm
Car: 91
Well
Putting a smaller radiator in the front fascia area. I had a 31 x 19 but obviously now it won't work with the turbo. Crazy stuff. Yhe tranny cooler will be mounted behind it and is about the same size as the raidator.
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Jesus... :hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail:
Just curious, what made you choose to put the intercooler there?
Deimos140
Sweet setup!
I am doing something similar, but I am running an X-trim. I like where you located the intercooler. Do you have any pics of it that might show the cage? Particularly where your front bars land in relation to the intercooler. That cooler is about the same size as the one I have here and we cannot seem to get in the dash like yours. I was about to just install it on the pass side floor until I saw your pics.
Thanks in advance! I know what your going through trying to fit so much stuff in a small package, and make it look good while doing it. You're doing an outstanding job, my hats off to you!
:hail:
:hail: :lala:
:hail:
Sweet setup!
:hail:
:hail: :lala:
:hail:
Car: 91
Well
The intercooler need the metal heater box cvut oput as well as part of the dah bracing which means I have to install a crossbrace. The rollcage is coming down just before the dash. I would tlak to Bob Hood. He is the super street racer who did it. That man has mad skills. The turbo is a 101 mm. She was built to haull. Hope I could help man. I would like to see your setup.
Car: 91
Oh
ANother problem we ran into with space is the stock master cylinder and power booster. The custom header is way to close for comfort so I have to run a manual chrylser master cylinder. Similar to the willwood one in summit. This got rid of the proportioning valve the only problem I can think of now is what to cut the piston length too. That and apparently turbo eat trannies so I have to geta really big tranny cooler. I had the B and M 70266 and that was way to small. Also anyone know on whats all involved ina 25.5 spec cage.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
That is a wicked setup man. What are the specs on the turbo size. Primaries? Cross over? Man nice work...
Car: 2000 Trans Am
VERY nice! Youve done an amazing job getting that all in there. What muffler is that? Looks like a bullet thats been cut down and rewelded.
Im getting ready to mounta similar sized turbo in my car after the first of the year with an LS1 and have a large water/air cooler to put in the dash as well.
Again, nice job!
Again, nice job!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Oh
www.sfifoundation.com
Car: 91
Well
Classic industries has 4 inch tubing for exhaust Fast Times didn't tell me where they got theirs.
Linson
Aug 21, 2015 02:12 PM
