Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Will I make it?
Old Apr 13, 2005 | 06:38 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Transmission: TH350 3200 stall
Axle/Gears: 4.10's
Will I make it?
Im just finishing up my manual to auto tranny swap. Put a TH350 in it with 2800 stall and 4.10's out back. My RPM range is somewhere around 2000-7000. Will I make to the end of the track? Seems like I might be running out of gear and RPM's.
Old Apr 13, 2005 | 07:12 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
What size tires are you using? Unless you are trapping at real big mph, you'll be fine going through at 7000. With 26" tires you can trap at 132mph and with 28" tires, 142mph.
https://www.thirdgen.org/newdesign/t...ulations.shtml
Old Apr 13, 2005 | 08:27 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
That doesnt take converter slip into account.
Old Apr 13, 2005 | 09:17 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
So you think I'll be alright then? I thought I would be. I have 28in tires on it now, but my drag radials are smaller, I guess 26.
Do you have a simalar setup?
Old Apr 13, 2005 | 09:54 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Going to depend on hp as well, more power the faster you will accelerate and the more rpm you will trap.
I run 4.11's with my 28" tires and trap 6600
Smae gears last year with 29.5" tires I trapped 59-6000
Old Apr 13, 2005 | 10:06 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
Gotcha. So do you think I'm not going to run out of gear or have to let off near the end of the track at all? Judging by your full race setup, it looks like I'll probably be ok, considering I'm way more mild as far as horsepower. I just want to know if I have to low of gears in it, and if I'm going to be topping out too quick to even finish with full throttle.
Old Apr 13, 2005 | 10:23 PM
IHI's Avatar
IHI
If your set up to make power in that range you'll be fine. You just want to be sure your combination as a whole is working together, if your intake,cam,convertor, gears are not in synch your leaving alot on the table. A lotta guys over gear and the car runs out of steam rather quickly-example would be 4.10's in a TPI car that normally tops out in power at 4500rpm, sure it accelerate fast, but they could be going faster-if that make any sense.
I think if you run the 26" tires, especially if theyr'e radials you may have some traction issues and will be spinning alot higher rpm since the gear is tall and tire is short. 28" might be a better option for that gear, or go back down to a 3.73 with the 26" tires.
Old Apr 13, 2005 | 10:45 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I have a pretty mild 350 with a th350, a simmilar converter, and 4.10 gears. Last year with the 26" drag radials I would shift at 6000 and go through the traps at 6000. You should be fine with those gears and set-up.
Old Apr 13, 2005 | 11:14 PM
IHI's Avatar
IHI
Rouge, you get that motor fixed? coming up for the 1/8th mile race the 30th?, would be your cup of tea!!
Old Apr 14, 2005 | 09:49 AM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Yep, she's all back together. *knocks on wood*
that 1/8 mile bash sounds kinda fun... We have our first street night on the 29th, and I've got a score to settle with a stang So as long as i'm not dead tired, I might come up. We'll have to wait and see how everything goes between now and then.
Old Apr 14, 2005 | 01:39 PM
mean83z's Avatar
Car: 83 Z28
Engine: 355 c.i.
Axle/Gears: 4.10's
Alright sounds good. Thanks guys.
Old Apr 14, 2005 | 04:26 PM
IHI's Avatar
IHI
Glad to hear your back up and running, been there dont tha before, at least the points have'nt started yet.....like you said knock on wood.
If your hitting the night drags, and they're like ours you'll be there till 3-4am and it'd be a waste of money entering a actual race since you'd be dead on your feet from racing all night then literally load the car and drive up here
Good luck, and show'em how to get'r done
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
