Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Whats the best shift point for L98/700R4???
Old Jul 6, 2005 | 11:51 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Ive been noticing my car has been shifting a little higher than normal in the 6100 RPM range. I know the TV cable adjustment can fix this, but what is the best shift point? Am i losing power after 5500 RPM with the stock internal L98? It doesn't really feel like its falling on its face. The 2-3 shift is where it seems to really wind out. Thanks
Old Jul 7, 2005 | 12:13 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i never shifted higher then 5500 with my tpi
proven at the track too, that was my best shift point
Old Jul 7, 2005 | 03:07 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I wounldnt shift after 5000RMPs with the stock heads and cam. Your just over reving after that
Old Jul 7, 2005 | 09:19 PM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
Your Tach is probably off a little. Mine says I shift at 5,300 but like you, there is no power drop off. So it's probably more like 4,800. I've tried playing with the TV Cable at the track and with lower shift points, my car slows down.
Old Jul 7, 2005 | 10:12 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Try around 5 grand.
Old Jul 7, 2005 | 10:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
does winding out first gear abit into the low 5'sK help out the second gear drop? cuz 3.06 first to a 1.63 second is a hell of a jump down, and maybe sacrificing abit in first will pick up 2nd gear
Old Jul 7, 2005 | 11:43 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Yeah my tach may be off a bit. I did adjust the cable and it feels alot slower shifting at 5 grand. It don't downshift for crap when i really nail it. When It reved higher in the 6 grand range the rpms would drop into a sweetspot (3500 rpm) on every upshift. I think my 4.10's might like the higher rpms maybe???
Old Jul 7, 2005 | 11:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i know mine is pretty much on... i trap 96.6 mph and with my gears and tires, its calculated at 3500rpms crossing the line, which is what it did
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
