350 combos
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
350 combos
ok i know i could probaly find the results in search but i will jsut post a new topic and if there is a old thread well post the link. could everyone that is running a 350 carb motor please post there times and there combos. i am trying t odial my car in and i just wanted to knwo what everyone else with the same size motor was running. tunning this thing in is driving me crazy!!! thanks in advanced
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Using engine size will not necassarily make for good bench marks. Maybe someone with the similarheads, compression, chassis and weight.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
ok i can agree to that. so my heads are the perfomer rpm, compression is 13.5, stock chassis tube stuff under it and south side 9 inch w/ 4.30's, weight is around 3200, th 350 trans w/ custom ati 8 inch, cam is a roller .577/.608, 242/262, 114 best pass so far is 11.59 @ 117.
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
FYI:
87 Firebird Formula roughly 3200 lbs. with driver
350 .060, 12.6:1, 5.7 rods, 3.48 stroke
ProAction 220 54cc Heads, 2.02/1.60 valves, 1.5 roller rockers
272@.050, .570 lift solid flat tappet cam
Hurricane single plane intake
750 mighty demon carb
1 7/8 Hedman Headers (Stahl bolt Pattern)
TH400 trans
Edge 9.5 4500 converter
9 inch rear, spool, 4.56 gear
28x9 Hoosier slicks
Best ET-11.19 MPH-123.6 60FT-1.53
Best ET-11.12 MPH-122 60FT-1.52 with same setup except 4.56 gear was changed to a 5.00 gear
TH400 trans
28x9 Hoosier slicks
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
ok tommyboy you have the bigger heads i think the edelbrocks are like 170cc. i know there hurting me, but you still have .4 tenths on me and that what i am talking about. i do have a 850 dp 1.5 rockers as well, 1 3/4 hooker headers. i was thinking about changing the heads and cam but this is what i have now and i still think theres something left in the car. right now in the carb i have 65 jets in it all around, but the plugs look good a tanish grey color. the exhaust temps are around 1300. to me that seems low. well thakns for the info already any more will help.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i think performer RPM heads suck for how much they are. Furthermore, that cam is a nitrous cam isn't it? that is a lot more duration on the exhaust than the intake. Did you try moving timing or jetting up or down to see if MPH picks up at all? Otherwise it's still a nice combo bluebeast. 11.50s is nothing to scoff at.
Well judging off MPH you are making about 418 fwhp, your ideal ET is 11.51 - you are close - but I would look for better 60ft's still as a race type car IE: small converter, deep gear, trans brake should be lower than ideal by about a 1/10 od 2 et..
I would look into a different cam as well, unless those are really un effecient on the exhaust - thats a huge split and pretty big lsa as well.. Great super charger cam!
porting the heads maybe - what do those flow??
Still a very good runner, and nice car you have.
My old 350 combo was dart 200cc, 10.0 compression, 3200 stall, 4.10s, victor
jr,750dp, 248/252..
11.87@112.8
jr,750dp, 248/252..
11.87@112.8
jr,750dp, 248/252..
11.87@112.8
jr,750dp, 248/252..
11.87@112.8
I'm EFI, and my engine is a 436, and it traps a MPH of 118. I should be trapping a 125 MPH. You and I have the same problems...WRONG CAM.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
i got a great deal on the heads that wh y ihave them on the motor now but now i am seeing the downfall. someone else told me that the cam is a nitruos cam. i guess i will get it as good as i can and look into a new cam and possibly new heads. i am not sure what these heads flow, so i couldnt even begin to tell a number. any cam for recomendations or shold i jsut give comp cams a call and let thme set with up with one?
Car: 1984 Z28
i'm happy with the 106 LSA cams on a N/A motor. comp makes some great circle track cams that have very peaky powerbands that you should check out on their website.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
went to track again last night a ran a new best of 11.455@119.1 with 60's in the low 1.5's. all i changed was the jets went up 2 sizes with them. i thought i better try something, and it worked. i am going to try one of friends 750 dp just to see what happens.
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
Here is a little trick that will help if you have a solid roller. Tighten up the valve lash .006 to .008 (Max). This should help out a bit. Assuming you have enough piston to valve clearance to try it. Another trick, buy a Moroso or Mr. Gasket electric water pump kit ($60.00). This will add some ponies too.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
its around 7000 at the traps could be 6900 could be 7200 i ma trying to watch the oil exhaust andd tach at the line, yeah there close together but u know how it is sometimes i look at the oil and forget the rest and sometimes i look a the other ones. but anyway its around 7000.
