Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
possible high 13 with this set up?
Old May 17, 2008 | 10:36 AM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
1989 firebird formula 305 TPI with a T5 swap,drag radials,slp runners hooker headers, Y pipe,no cat and 3 inch system and stock 2.73s thx
Old May 17, 2008 | 10:46 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: possible high 13 with this set up?
Doubt it, that gear will kill you for one, for two, if it is a factory auto, that 305 doesnt make the power thet factory T5 TPI car did.
Old May 17, 2008 | 11:48 AM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
ok with some 3.42s?
Old May 17, 2008 | 12:09 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Probably not, maybe with a cam.
Where's ridge?
Old May 17, 2008 | 12:19 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Where's ridge?
lol out east L.I..were are you lol
so with my current set up im proli somwere of 14.5 rite?
Old May 17, 2008 | 12:23 PM
327???'s Avatar
I'm west of rochester, up near lake ontario.
14.5 is a decent guess.
Old May 17, 2008 | 12:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i dont know if your that fast yet.. you need alot more gear and some tuning to get the full advantage of those mods with the stick. Also a cam swap should get you in the high 13's
you will need to cut some great 60 foots, something in the low 1.8x range and trap near 96-97 to get high 13's
Old May 17, 2008 | 12:52 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i guess 14.7 maybe 14.3 with cam
Old May 17, 2008 | 08:30 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
use a bias ply slick though....those drag radials won't like the shock of a t5
Old May 17, 2008 | 08:40 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
were can i get some of those? thx
Old May 17, 2008 | 08:47 PM
mw66nova's Avatar
Engine: 7.0L
jegs, summit, whichever
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
