well, my junk finally went into the 8`s in the 1/4
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
It was not pretty but it did (in car and outside car video later!) 8.97 @157.93 had to use way too much No2 and ran out of gear at the 800-900` mark but it went.. Best part of the day was the improvement in the 1/8 and 1/4 on a 150 shot...picked up to 127.47 on the 1/8 and 154.3 mph in the 1/4 but still at 9.17 and 6.02
One thing I gotta say is, the 16volt battery / alternator combo is the best thing I did over the winter, voltage never dropped below 15.7 volts even with the fans,water pump,fuel pump, 7al2 ign and bottle heater on Cranks over like it doesn`t have a lick of compression too! Nice day though, windy and 50* good to stretch it`s legs...IT BEEN A LONG WINTER!!!
Re: well, my junk finally went into the 8`s in the 1/4
you S.O.B!!! you didn't even call. You know the rules!!!!!.
Well, did you get kicked out? Was our mutual friend talking bad about me? I'll be expecting a call tomorrow with all the details.
Congrats man!!!. I'm so proud of you and the car. Now i need a shot of the car wheels up for my hall of fame.
Mike.
Mike.
congrats, did it take a 250 or 275 shot to make it there? welcome to the 8 second club though.
Congrats on the new times !!!
First slip here is the 150 shot on the progresser starting on 60% ramped in in 1.5 secs (most of my reactions were .800 range ) This was a real surprise from last year, all I did was upgrade the bottle to a 15 lb, feed line to a 6an and solenoid lines to -4 from 3an`s
Second slip here is the 150 shot progressed in starting at 60% ramped in over 3.0 seconds and the fogger jetted at 28N 24F on a digi set timer set at 2.2 secs for activation, pulled 4 degrees for the 1 kit and took another 9 degrees for the fogger, one hell of a scary trip down this backyard track I gotta say.
Car is awesome Greeze! That car is soo sweet looking, sleeper looking, stock style suspension! Th350 still! Bad as$ man! completely! That is flying man! I hope I can see one of those slips this year, well see though.. I actually had same 1/8 et of 6.0, just 10mph slower Your car should be on the home page of TGO!
Congrats man! You worked hard for it!
Drop that 60' a little more and it'll get it done on less of a shot. Definitely hauling the mail. Should have mine out in a little over 2 weeks at the track, hoping to keep it together this season, even have tickets to pinks all out so hoping for some air time
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Thanks IHI, Looking to hear good things from yours too this year!
And here are some video links, quality is terrible but I wasn`t trying to produce a movie this weekend, at least I got something!!
down track video
In car video
down track video
In car video
Makes two of us someday i'll smarten up and go pig block and i'll be buildin to surpass 9's as well, since well, IMO you put something that big a cid up front it'd better perform otherwise it's not worth the time. just got the front end limiters installed this afternoon, so going to find out soon if it's going to work with my junk or not..trying to keep this thing flat on the leave.
Well, I`m still trumped by a certain 434 I know of and a 421 , both SBCs and both running 23`s, the 421 is rolling 8.80`s with 400 on two stages, the 434 8.50`s...Then there is another 434 on 3 stages that runs in the 7`s constant...I just like a full engine bay I guess, because I could get it done with alot less like these guys do.
Greeze- there's definately some potent sbc stuff out there, but when i go pig block it will have to be built to what i expect from my junk now. pump gas first and foremost, i refuse to have a driver that has to run $6-12/gallon fuel, and one i go larger cubic inch it will run at least 9.0's otherwise i see no benefit to going larger everything expense and shoehorning wise. last must not least it must be able to be driven with no special attention, no babying, and no maintenance other than normal oil changes...aka, no monster cams that eat up springs every two weeks/month like alot of these monsters out there. I realize i'll never have the funds to be the baddest on the block, and i fi wanted to be, it's have to be turbo'd, S/C'd, or multi stage nitrous since NA can only get you so far....but i see what standard 23* sbc can do on pump gas, so for now i cant understand why having another 200hp on top of that with the extra cubic inch is'nt feasable is all.
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Congrats, That's a pretty sick down the track video even if it is low quality at less you can see it's a camaro, that's all that matters.
just seen the vids ya linked.
1st vid, that sum beeotch is digg'n, sounds great and looks good fromt he distance
2nd vid, dude, snuff out the doobage before making a pass
Nice vid, that car looks likes its really moving
Go turbo sbc. Thats what i'm doing and it should easily go 9's. You can fab up a nice single setup for fairly cheap. even a twin setup isnt all that costly
LOL, at face value it's not bad, but getting everything working right and working right for a long time with no tuning/maintaining is another story. I have a number of freinds locally that have all been trying to get their turbo and S/C'd cars to run good CONSISTANTLY and it just has'nt happened, and i just keep going faster and attending more car events then they do The two guys that are heavy into this have spent well...WELLL over $10K just in shop fees/dyno fees, computer programs, computer software to try and tune their stuff. They'll get 1 half azzed pass, then boom, it'll be in the trailer with a problem/software glitch nobody can seem to figure out....around here there just is'nt anybody doing much with that stuff with any sucess so until they do, i'm all done being the guinea pig with my own funds, time to let somebody else take my place LOL!!
1 Post
Car: projects.......
That's getting it done for sure! Congrats on the time man. Get that 60' back in check and you'll be hitting the number with a lesser shot.
You went from -4 lines down to -3's? Are they still larger than the pill orifice? - wait, are we talking plate kit or fogger?
Thanks, I have to get up to par for safety stuff (chute,fire pants) but I expect it to go that # on a 250 eventually. I went from 3an flex lines on the plate TO 4an lines and it made a noticable difference big 1/8 mile gain
1 Post
Definitely get the safety stuff up to par. I've seen too many reasons to have more than needed. - I must have read that wrong on the NOS lines; good deal.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
3AN lines orfice is only like .073. I learned the hard way this year by buying new lines and increasing the pill size and not seeing any results. The hard lines are .120 from NOS if you use them.
Just got the chute, WING and related saftey equipment, few days to get it on the car and I`ll be back out there
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
i wanna see the WING!!!! is it an ed quay?
Car: 1982 Camaro
Engine: 555 BBC
Yes post pics of the wing installed. I may be in the market for one also. If it's like built small block Quay headers. Than it should be a top notch piece. I can't wait fo rmy bbc headers in two weeks.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
im game to see the wing too.
ive never seen a good shot of a wing on a 3rd gen.
i am also on the band wagon of folks that want to see the wing. scott, dude, that thing is SCREAMIN'! i just saw this thread, been busy trying to get ready for the wedding (17 days and counting!) so i haven't been on much. i'm gonna hit the track up some this summer, and after all these cars on here getting faster and faster while i'm sitting on the side lines watching, i may just have to pull the trigger on a kit...
1 Post
^ Matt, in case I don't get a chance again before, congratulations man! I'm just past 7 months now with mine.
I'd be interested in the wing manufacturer & some pics as well. - Check the instructions on mounting the chute properly in relation to the wing.
Car: 1987 IROC
Engine: 350 vortec
I left the stock spoiler off my berli just so i can use a wing once i get the car rolling again. o yeah matt...get the kit its waaaaaaaaaay too much fun
thanks shaggy! i'm really excited.
you know, i was pricing out a kit last night, and i can get into a really decent wet kit for about $600, that's really not that much in the grand scheme of things...
anyone have any suggestions for what kit i should look at? i'm running a speed density tune and an ls6 intake with a cam that'll love the nitrous: 212/219 on a 115lsa
ls1tech has a ton of sponsors with nice kits. The throttle body ring one sure is fancy Just remember to pull lots of timing and shoot for a good a/f ratio....having them tuned on a dyno wouldn't be a bad idea at all. Figure around a grand IMO to get yourself running on the nitrous, $600 doesn't cover everything. filter, heater, purge, blow down tube, the fitting for the blow down tube, etc etc etc. It all adds up, oh then the $4 a pound to fill the bottles plus buying 1-3 spare bottles as well
#42
bwahahaha, ah yes, the nickle and dime bullsh!t...that's just the story of my life though steve!
josh, i just realized this, you're still using the stock front binders! what does that feel like on the big end after a 130mph pass?!?! scary bro...i'm glad i did the ls1 brake upgrade over the winter, it was a HUGE improvement over stock...the added weight over the stock units was negligable, maybe not even worth mentioning.
#43
Car: 1987 IROC
Engine: 350 vortec
i'm running a BRAND X kit from nitrous outlet, about 650 bucks bought the universal kit and the accessory pack, then i got an extra bottle. got about 800 in the whole setup, the 100 horse hits like a freight train, gonna put in colder plugs and try to go to 200 tomorrow night, the ol' 305 TPI is going for 7s or bust....quite literally
#44
i was wondering about the nitrous outlet kits...how's the quality?
edit, i just realized that nitrous outlet is a distributor...so the question remains, but for the "Brand X" brand.
#45
Car: 1987 IROC
Engine: 350 vortec
for the money its good stuff, the bottle doesn't have any accessory ports on it, which really sucks, but the nozzle and noids seem nice. it uses NX jets if that makes any difference to you, but its solid stuff. Nitrous Outlet's house brand stuff is pretty good from what i've heard. the noids are good to a 200 shot...which is about as much as i'd want to spray out of a nozzle anyway. or check out their ebay store and sometimes stuff is cheaper. store is nitro dave's nitrous outlet. but anyway, sorry for the hyjack!
#46
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
congrats greeze, that things cookin!
#48
#49
The chute is a stroud 4301, I was going to pick it up at Strouds but they were out of the black, jegs got the call on it, it should be on the car by weekend`s end
And to everyone else YES it`s an ED Quay wing, full width with side spill plates, I will get pics of everything once it is on the car, could be a few days for sure but I`ll post a pic of it on a car for you guys
#50
From Ed`s website:
I`m planning to put the support tabs on top of the bumper, the way this one was put on is not the best example, it`s tipped up way high and they mounted those tabs as far from the spoiler as possible. I picked up a 4130 3/8 tube parachute pack mount, I think I can get it all to come off the license plate area. I made a bolt on mount for the anchor mount, removing the stock bumper I used some 6x6 1/8 steel plates and a 1 5/8 steel tube to span the width all welded together, should look pretty close to the wolfes design for the 4th gens when it`s done.
