Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
60' Time?
Old Apr 14, 2002 | 10:13 AM
Beefy89's Avatar
60' Time?
Anyone have an idea what my 60' times should be?
89 GTA,L98,96 LT1cam,1.6 roller tips,9.75:1 compression,fully ported L98 heads,mildly ported TPI,SLP 1 3/4 " headers,no cat,flowmaster muffler,Hughes 2500 stall converter.
I guess I'll have to get some drag radials,cus all it does is spin off the line.These are my results from the track y-day.(only made 1 pass)
ET 15.13@94.28, with a 2.781 60' time...........Thanks
Old Apr 14, 2002 | 10:39 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
2.78's are really bad. A 4 cylinder FWD car should do better than that. You should be 1.9's or 2.0's depending on your gearing.
Old Apr 14, 2002 | 11:01 AM
Beefy89's Avatar
Thanks Stephen.
If I were to get my 60' times down around 2.0,do you think 13s are possible?
Old Apr 14, 2002 | 06:44 PM
jamesbern's Avatar
You should be able to pull off a 13.99 with a 2.0 60 ft. time.
Old Apr 14, 2002 | 10:10 PM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
i pulled a 1.99
14.171
today at the strip with a 3.27 rear gear
Old Apr 14, 2002 | 10:15 PM
fattie92's Avatar
how do you even get traction?? when i was at the track i was spinning nasty style off the line and didnt even move! i tried to feather the pedle,, but same results.. maybe my tires are just shiit
Old Apr 14, 2002 | 10:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You've never said what kind, size, condition of the tires that you currently have.
Even an old used set of slicks can be considered worn out and slippery.
Street tires are not drag tires. They are made of hard rubber compounds designed for long life and are not designed to be heated up.
Invest in a second set of tires and rims for the track or live with poor and inconsistant 60' times with street tires.
Old Apr 14, 2002 | 10:45 PM
fattie92's Avatar
like i siad,, my tired are shiit.. they are just street tires at the moment,, i dont know the size without looking at them.. it was my first time ever to the track, and i was expecting it to be somewhat like the street,,,,ohh i was wrong!!
Old Apr 15, 2002 | 09:11 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
i pulled my 1.9 at byron on futura ultra z tires just lit them up good before each run
Old Apr 15, 2002 | 02:46 PM
fattie92's Avatar
i feel stupid "lighting them up" cuase i have a "one legger" (open rear)..
Old Apr 15, 2002 | 05:04 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
A LOT has to do with how well prep'd the track is. If it's a 'test n' tune' day, you more apt to have crappy prep...IMO.
Trans slippage, peg leg, crappy tires, poor track prep can all lead to horrible 60' times.
Old Apr 15, 2002 | 10:18 PM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Back when I was mostly stock I ran 2.0s-2.1s and 14.125 at 97 MPH. My best 60ft on street tires was 1.903 with my 2k converter and on my worst run ever I went 2.5 and I was all over the place and went a 15.3 if I remember right (1st time at the track and same night I ran 14.125). Since you have a converter Id invest in drag radials and watch what a difference they make the next time out. Before you do that though, Id invest in a good set of subframe connectors 1st, just to keep the car twist free...
Old Apr 16, 2002 | 10:10 AM
Chronos_Titan's Avatar
Why doesnt anyone every step up their suspension before the engine? SFC and new control arms in the back with, with a new torque arm bushing can work wonders. Just getting all those old bushings replaced can be a miracle. I am not recommending everyone go like me and backhalve the car. But updating that suspension can work wonders.
Old Apr 16, 2002 | 12:06 PM
85transamtpi's Avatar
A nice torque arm and some LCA brackets will work wonders on 60' times.
But if I were you I'd invest in a pair of Nitto NT555R's. The stick like glue when you air them down and warm them up.
-Doug
Old Apr 16, 2002 | 03:22 PM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
as stated ealier 1.9 on pep boy futura ulta z's that with no suspesion mods at all
Old Apr 20, 2002 | 11:26 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
For reference I just ran a 2.09 60' time on stock goodyear GSCs on my 91 formula ws6 5.7L. The car is mostly stock, just an air foil, open filter element and Ed Wright standard fastchip.
Old Apr 21, 2002 | 03:52 PM
RB's84camaroF-41's Avatar
2.16 peg leg LG4 on 14'' grand am gt's. pitiful rear, pitiful tire, pitiful engine but a decent 60 footer
Old Apr 21, 2002 | 04:04 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I average 2.16 on my 2 month old Goodyear GTII's, and I have a lot of mods to my rear suspension. Doing a burnout makes no difference whatsoever for me. I still slip off the line, and when going into 2nd. =/
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
