Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Insert new thread here
Old Jul 8, 2003 | 12:22 AM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Just thought I'd start another thread.. Fill in with topics of your choosing such as in the 150mph thread.
Old Jul 8, 2003 | 02:59 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
Re: Insert new thread here
my 455 gmc sprint has vtec
yunno,in reality i bet the sprint would hit 150..it had 2.56 gears in it *ponders thought*
Old Jul 8, 2003 | 05:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: Re: Insert new thread here
i bet it falls apart by 135
Old Jul 8, 2003 | 07:58 AM
rjmcgee's Avatar
Some pieces of it might.
Old Jul 8, 2003 | 01:26 PM
MarkB's Avatar
Engine: 383 -305
Re: Re: Re: Insert new thread here
lmao
Old Jul 8, 2003 | 07:15 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
so the tour de france is back in town... one of the few times you'll see french people waving their hands without surrendering.
:Shrug: heard it on the radio this morning
Old Jul 8, 2003 | 11:20 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
new topic
Ok here's one, what does everyone think of 2.77 gears on a 9bolt posi/limeted slip rearend?? Thats what i found out i had. The thing is, my car is in the shop getting the rearend fixed and i might have to get new gears..Should i go with 3.27's or 3.45's? What would you reccomend if i have to get new gears?
Old Jul 8, 2003 | 11:43 PM
Dewey316's Avatar
Car: 1990 Camaro RS
if you have an overdrive tranny go 3.45
Old Jul 8, 2003 | 11:44 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
The wife has B/W 3:70's in her HO, with a 5 speed it launches quite well
Mine has the gentler 3:27 Borgy, even barks second
3:27 would work good for you.
Don
Old Jul 8, 2003 | 11:55 PM
PonchoTA's Avatar
Re: new topic
:cough:buymine:cough:
Old Jul 9, 2003 | 12:01 AM
CheezX's Avatar
I fixed my traction problem by cutting my springs
Now I can't spin the tires.
And that's on crappy bald all seasons
and the brakes feel better after undoing the top of the strut and letting the whole suspension hang by the line heh oops
Does anyone know where I can get a 400 block? I still can't find one close enough to pick up. Cause heads with 2.088 valves don't fit on a 305.
Old Jul 9, 2003 | 12:03 AM
Poncho, what rearend did you have? I dont want to get 3.73 because that would really kill me in gas milage. I figure a 3.27 would be good for both milage and performance.
Old Jul 9, 2003 | 12:41 AM
PonchoTA's Avatar
Hey dood!
Yeah, I have the 3.73's, but with the OD gear, I've always gotten 20-25 mpg, even stuffing my foot in the middle of the carb sometimes!
Comes with a whole slew of **** too, adj. Hotchkis panhard bar, BMR lower control arms, KYB's, T/A girdle cover, brand new posi (barely 600 miles on it!), alum. driveshaft, 1LE rear discs!!, great rubber (maybe 2 or 3 thousand miles) on the front, etc., etc., etc.!
Let me know...
Paul
Old Jul 9, 2003 | 12:45 AM
and u want $1800 for all? Im currious of what gas milage and also what top speed i could reach with those 3.73's. I have had a gas milage problem for a while but i think its my fuel filter. I'll have to change that but i dont know if ill need the rearend first or not. I want my car to be able to do 140 but still do really good around town and at the strip. I also dont have $1800, i lost my job a little bit ago and i could probably only afford up to $800? Depending on what my parents would do.
Old Jul 9, 2003 | 05:53 AM
Dewey316's Avatar
Car: 1990 Camaro RS
if you have OD, it shouldn't be bad at all, i just switched to 3.42's and my gas milage so far (2 tanks) has been better than it was with the 3.08's
Old Jul 9, 2003 | 07:12 AM
PonchoTA's Avatar
Actually, now it's closer to $1500 (willing to deal) and I have a bunch of other miscellaneous stuff that would go with. It just needs to get gone! Sooner = better! Make an offer, let's dicker!
In the bigger scheme of things, there won't be a huge difference between 3.73's, 3.42's, OR 3.27's, mileage or otherwise.
There IS a bigger difference in SOTP feel between 3.73's and say 2.73's, mileage will probably suffer too, but I have another theory on that! (You like the greater acceleration so much that you get on it more often than not, so THAT'S why the mileage goes down! Not simply because of the gears!)
Anyway, let me know if you are interested, maybe we could set up a meet, or, whatever!
Paul
Old Jul 9, 2003 | 12:26 PM
Is all this stuff actually on your car or is it seperate?
Old Jul 9, 2003 | 01:53 PM
PonchoTA's Avatar
All goes together!! Buy a rear, drive it away! (just think of all the spare parts too!)
Hell, the entire front end suspension is all still fairly new, PST (polygraphite) and Moog components, new brakes, braided Earl's brake lines, you name it, it's probably on there!
Easily $2500 worth of stuff and labor into it!
Only problems I'm aware of, besides the body work that is, is that the driveline still kinda vibrates at about 60-70 mph because the driveshaft needs better balancing, and the tranny still has problems shifting (5th to 4th, etc.) It DOES shift fine when you get it going, but it has "quirks"!
You can pm or call later this eve. if you want to chat about it.
Paul
Old Jul 9, 2003 | 04:10 PM
well if its all with the car i know i wont be able to do it. I have already talked to my dad about a parts car but he said NO. We dont really have the room to store onother car. Sorry.
Old Jul 9, 2003 | 09:27 PM
PonchoTA's Avatar
Man! That's too bad, I would think it would fairly easy to swap the stuff off of it that you wanted, then just sell it off for whatever, you know, win-win!
Let me know if you change your mind (or it is allowed to be changed!) or... if you have a buddy that NEEDS a runnin', drivin' project car!!! (this was my daily driver for about a year! Definitely reliable!)
Old Jul 10, 2003 | 03:28 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
how much for the whole car? and waht engine does it have, what are the total specs on drive train, i might want it for the birdie for parts.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
armybyrd
Oct 24, 2015 06:59 AM
Linson
Sep 21, 2015 01:08 PM
Numbah-1
Sep 12, 2015 08:57 PM
