Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
attn: rx7speed
Old Feb 9, 2002 | 03:21 PM
age's Avatar
age
Car: 1992 Z28 1LE
attn: rx7speed
I was thinking of buying the latest generation RX-7 that came out in the early to mid 90's. If I do get one it'll be in at least a couple of years (want to "finish" building my Z28). I was wondering if you knew of any problems that plagued it. I've heard that it had A LOT of electrical problems (a former friend used to work at Mazda). But that's just one person's opinion.
Are parts really expensive and hard to find? thanks!
Old Feb 9, 2002 | 10:32 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
the latest ones (92-95) are sweet as hell
but the problem is that they tend to be about a 80k mile motor
as far as elect problems not sure with those years
problem with them is due to the boost and if you run crappy gas you get detonation and these cars do not like detonation at all
and also ppl tend to put mods onto the car that up the boost and airflow and forgot that the car needs more fuel so.... more air but no more fuel equals lean and that will make for detonation
if you do the mods right and make sure you have enough fuel your motor should last for a little longer then 80k though
just most ppl do not take care of the car like they should
these things NEED to have the oil changed every 3000 miles
need to have the rad flushed once every year or two (unless you run evans NGP coolant)
www.evanscooling.com I would go there and check there stuff out.
for the most part you just take care of it like you should do to any car and you should be ok
so far 171k on my N/A motor still kicking strong. just having a problem with the fuel right now. I think I have a messed up injector.
I know I'm prolly scaring you away from the car but they honestly are not that bad
again most there bad rep comes from ppl who think they do not have to take care of the car like you can get away with on a piston motor. so they change the oil every 10-15k miles or forgot to flush the coolant you know crap like that.
you take care of the car (that doesn't mean drive like a grandma though since these cars are made to be driven hard and even helps keep things clean) it will last a while
just remember if you get one fuel first then do the rest of your mods
I know mine 86-91 (they did have a 92, lucky japan got it though and not us grrr) there are problems with elect stuff but it is like your clock will flicker on on off or the heat unit will quit working
most can be fixed by doing a cold solder on it and then it will last for some time.
easy fix.
if you want a car that can last for a while get a 2nd gen n/a
200k+ miles not uncommon
you should really have to much of a problem with parts as long as you take care of the car though if you buy dealer go with your vasoline. they will rip you off
only place I really would go to buy parts for these cars are from
www.ebay.com
www.thepartstrader.com
www.mazdatrix.com
www.racingbeat.com
most the parts from them will be ok
and these cars do not tend to break parts often since they are built kinda tough
but if you are set on getting a thirdgen the one to look for is a 93 R1
they have the stiff susp that can pull .99g (almost that of the new z06, about a 67-68 on the slalom
0-60 I have heard 4.7-5.3
1/4 at about 13.8
but they are so easy to mod since they are turbo
just remember FUEL FUEL FUEL
if you have other question or I didn't really give you enough info just let me know
but trust me you get one you will not regret it at all
Old Feb 11, 2002 | 09:09 PM
age's Avatar
age
Car: 1992 Z28 1LE
thanks for the info! Yea, I really like the 92-95 style. Especially with a body kit (not "overcooked rice", tho), mags, etc.. Right now, I am thinking of getting the evoluzione body kit for the F-bodies, but I haven't ruled out the RX-7, Supra TT, or the C5 ( I work for GM, so a used C5 would be attainable after a few years).
Old Feb 12, 2002 | 05:39 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
just a few rx-7 pics
Attached Thumbnails attn: rx7speed-redcar.jpg
Old Feb 12, 2002 | 05:41 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
and yes this is normal if you have nothing more then a free flow exhaust
Attached Thumbnails attn: rx7speed-rsflames4.jpg
Old Feb 12, 2002 | 05:44 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
one hella fast rx-7 with a body kit I kinda like
Attached Thumbnails attn: rx7speed-cheatham_rx-7_10.jpg
Old Feb 12, 2002 | 05:45 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
one of my fav colors on the thirdgen rx-7
Attached Thumbnails attn: rx7speed-i-1_b.jpg
Old Feb 12, 2002 | 05:46 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
a motor shot of the same car
Attached Thumbnails attn: rx7speed-i-6_b.jpg
Old Feb 12, 2002 | 05:48 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
a sweet *** body kit for the second gen (86-91) rx-7
Attached Thumbnails attn: rx7speed-maiah.jpg
Old Feb 12, 2002 | 05:50 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
nother flamage shot
great way to get rid of ppl who ride you butt
Attached Thumbnails attn: rx7speed-p0005185.jpg
Old Feb 12, 2002 | 05:51 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
hehe yet another picture of a thirdgen
Attached Thumbnails attn: rx7speed-sideview1.jpg
Old Feb 12, 2002 | 05:53 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
another second gen car
Attached Thumbnails attn: rx7speed-1221.jpg
Old Feb 12, 2002 | 05:56 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
this should be my last one for the time being
I have more though if you want them
just talk to me on aim if I am home
aim = rxspeed87
also if the pics dont show just right click on the red x and then click on "show picture" that should bring it up for you
Attached Thumbnails attn: rx7speed-feedwidebodykit1.jpg
Old Aug 2, 2002 | 12:15 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
just digging up old post
hey don't remember if you got the car or not just curious as to what happened
Old Aug 2, 2002 | 01:03 PM
psycomaross's Avatar
check this out. It's a Supra TT engine in an rx7 shell. The hood had to be custom made for the turbos and engine. I wouldn't mind the next camaros looking like that though, but without the turbo scoops and stickers.
Old Aug 2, 2002 | 01:04 PM
Oops forgot the pic
Attached Thumbnails attn: rx7speed-supra-7.jpg
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
90TA
Jan 20, 2003 09:05 PM
muchwhitesmoke
Jan 8, 2003 10:44 PM
Mark A Shields
Theoretical and Street Racing
Apr 25, 2002 11:37 PM
rx7speed
Aug 31, 2001 05:01 AM
