Finished mounting the autotensioner
Old Nov 30, 2009 | 08:33 PM
AC's Avatar
AC
Car: Used to drive a camaro
I've wanted to do an autotensioner for my procharger setup forever. While building engine #4 for my car I decided, hell, no better time than now. The belt is pretty taught and the tensioner marks on the outer diameter are where they should be, BUT if the belt gets too close I'll add a ribbed idler pulley and use a longer belt.
Old Nov 30, 2009 | 10:55 PM
livinforhim's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6
Transmission: 700-R4
Re: Finished mounting the autotensioner
please excuss my ignorace, but what does the autotensioner's purpose? is it to compensate for the horses lost to drive the procharger?
Old Dec 1, 2009 | 12:24 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Here is my Autotensioner for procharger, works perfect along with my homemade "bracket"
Tensioner
https://www.thirdgen.org/forums/powe...ioner-ati.html
Bracket
https://www.thirdgen.org/forums/fabr...r-bracket.html
Forgot: I removed the lower Idler pulley and kept the stock adj.pulley. This gave the autotensioner more room to work before the belt would "touch it self". Done that- been there
Old Dec 1, 2009 | 01:12 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Looks badass AC!
Old Dec 1, 2009 | 03:14 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
the autotensioner is so that it'll keep constant pressure on the belt instead of using a manuel one where you wouldhave to adjust it every couple months when the belt stretches AC looks great man AC is that off a diesel truck or something my truck at work as one that big ?
Old Dec 1, 2009 | 06:15 PM
AC's Avatar
AC
Tom, yeah, the tensioner is the Dayco part number floating around. Thre thread that gta324 started Tensioner
https://www.thirdgen.org/forums/po...ioner-ati.html
has the 2 different part #'s I've seen, including mine. The tensioner I'm using is from an International brand truck I believe. I'm going to see what happens if I use the old manual tensioner as a fixed position idler instead. I'm not getting warm and fuzzies about the belt face only 3/4" apart even without the engine running.
Old Dec 2, 2009 | 07:17 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I tried that on the C4 I had, and it didn't provide enough tension.
-- Joe
Old Dec 2, 2009 | 08:00 PM
AC's Avatar
AC
anesthes, what rib # were you using? 6,8,12?? I DON'T want to go cog from what I'm reading and the side effects of using a manual tranny with that. I look at it though and see the autotensioner being better than the manual one.
Old Dec 2, 2009 | 09:25 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On both my vortech and powerdyne I used a 6 rib, and both were manual trans.
The vortech slipped initially with the manual, until I changed which side of the belt it put tension on and then it was flawless.
The powerdyne I used the spring loaded auto tensioner and it slipped. Switched to a manual and no slippage.
Obviously too much tension and you might eat the bearings on the head unit. can't win. A really good BOV with large capacity is also needed, when I first started playing with the vortech in 2001/2002 I'd blow belts clean off shifting with the 5 speed lifting the throttle between shifts
-- Joe
Linson
Sep 21, 2015 01:08 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
