http://home.austin.rr.com/bordelon/TIM3-01.jpg
http://home.austin.rr.com/bordelon/Tim908slip.jpg
http://home.austin.rr.com/bordelon/Tim914slip.jpg
This is a local guy running a t88 on a stock 32v cobra motor. (stock as far as the heads,cam, bottom end is strong of course.) I thought it would give you some incouragement for when your car is done.
He said it was a t88. I dont know much about turbos. I thought guido was running a pt 88.
ya, thats the same size turbo that Guido has
difference is that the DOHC cobra was made to rev and loves boost
and
Guido's 400" has tiny heads and a hydraulic cam....so he's not making his goals very large so that way he can kick the crap out of them
and
I hope to run high 9's after I figure which blower to run. These dam afr 227's have been a pain in the *** to get working right. Ill have some N/a times after wed with the 8 to 1 compression.
Monty
close
- Join DateFeb 2001
- LocationPark Ridge, IL
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- CarOld Car - 1982 Vette. New Car - 1972 Vette Convertible
- EngineOld Car - 1200hp TTSBC 427. New Car - TT LS7X
- TransmissionOld Car - 4L80E. New Car - TBD
- Liked:0 Times in 0 Posts
Sick!
Here's a NMRA car the shop that fabbed my headers built before mine. It's a PT88 as well.
I SURE WOULD love to go that fast but we will see. I keep saying 9.80's for myself but everyone else tells me its going to be faster than that.
*shrug*
Ill chose modest at this point.
Yes mine is a T88.
*shrug*
Yes mine is a T88.
I think I've seen that mustang before. If it's the same one I'm thinking of is it not putting out something like 1400hp?
B4Ctom1
close
For a second I thought you said it was a stock cobra motor, then I saw you wrote "stronger bottom end". which is good because around 500 rwhp they usually rip the piston off the spindley lookin rods. we have built both turboed an supercharged cobras and have seen it happen. Ron Anderson Products (maker of power pipes for superchargers) said they have found the same thing. none we built were 9 second rides, daily drivers running 11's at 6000 feet was all.
Quote:
Alternative Auto got stock cobra motors to live for a long time. Or so they say. Originally posted by B4Ctom1
I got to see one of their cars at Cyberbrawl a couple years back a green notchback 5.0 stang with a cobra mod motor in it and a t-trim vortech. They were running 26psi unintercooled boost into a stock block. They claimed that all they did to the block was add shims under the valve springs to bump up their pressure rating. They were revving the engine to 7800 rpms. They DID have a speed pro and large injectors. Ford 9", full cage, custom stepped headers but the motor they claimed was a stock motor. They ended up breaking a piston at that race because they were experimenting with higher rpm shift points. They said they pulled the rod out of the bottom of the piston, but didnt break a piston due to boost.
Is that amazing or what? That says alot about the durability of the combra mod motor if treated good.
Quote:
Originally posted by Jza
Happy Birthday! (I guess)
Yup today is my birthday. Originally posted by Jza
Thanks!
:hail: :hail:
