What head gasket should I use with nitrous?
Old Apr 21, 2002 | 04:21 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I am installing a ZZ4 partial engine block with flat top aluminum pistons and AFR 190 cc aluminum heads with 58 cc combustion chambers. I am also going to use a 150 shot of nitrous oxide. What head gasket should I use for this combination? Thanks for your help.
Old Apr 22, 2002 | 01:30 PM
Does anyone want to answer this? Has anyone ever heard of the Silicor gaskets my Mr. Gasket (Victor Reinz)?
Here's the link http://www.mrgasket.com/maincat.html
Click on the Mr. Gasket catalog, then on Gaskets, then scroll to page number 3.
Old Apr 22, 2002 | 03:40 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I like the Fel Pro 1010 gasket for N20 and aluminum heads.
Old Apr 23, 2002 | 10:02 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the solicores and the 1010's are cool but this is the mack of all daddys, the 1045 loc/wire check it out here http://www.federal-mogul.com/felpro/...ets/pg_44.html or http://www.bhjinc.com/tools/o-ring_a...ve_cutter.html
Old Apr 24, 2002 | 01:10 PM
TBurke's Avatar
fel pro 1010
Old Apr 24, 2002 | 01:16 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Fel Pro 1010
Old Apr 24, 2002 | 03:42 PM
Just out of personal experience, I've had a friend of mine use the Fel-Pro gasket #1010 on his aluminum headed 350 ci. with nitrous. It began to leak after a couple of passes with the N2O. The Loc Wire head gaskets from Felpro (#1045) are great but require head machining to accept the oversized wire ring on the gasket.(which I'd rather not do) Do the Silicors have similar sealing abilities and strength?
Old Apr 24, 2002 | 04:10 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
I have the Fel Pro 1010's on my motor right now and have went through about 15 bottles of N20 with no problems. I have used these gaskets on a few other engines with aluminum heads and N20 and never had a faliure. Did your buddy tourqe the heads after running the engine through a heat cycle?
Old Apr 24, 2002 | 04:38 PM
As far as I know he did go through tourqing the bolts after the heat cycle. It started leaking coolant externally from the head gasket (coolant dripped outside along the block).
Old Apr 24, 2002 | 06:25 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I have heard about problems with the #1010. If you look on AFR's website, they used to recommend that gasket on their heads, but now they say to use the 1003. There were some guys on the corvetteforum that had problems with the 1010 and the ring around the cylinder blowing apart. Not sure though.
I use the victor reinz #5746 .026 compressed thickness.
Old Apr 24, 2002 | 06:57 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I like the 1003 as a regular type gasket because it uses a preflattened stainless steel wire as apposed to the 1010's weaker preflattened copper wire. in the cylinder head applications column the 1003 lists "for cast iron or aluminum heads" and in the aluminum head brinneling column it lists "minimal"
Old Apr 25, 2002 | 03:15 PM
87Z-ya's Avatar
I had problems with the 1010. I now stay away from it. Im running the 1014 on my boat with afr's due to the fact it sees no coolant and gasket material deteriorates. I use the 1003 on my car as per afr's recomendation.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
