Cog pulleys for Vortech
Old Aug 6, 2002 | 12:39 PM
BlownBird's Avatar
I am selling a set of cog pulleys made for the Vortech s/c on a thirdgen. They are made by Auto Specialties, and include the crank pulley (with the serpentine and cogs), the s/c pulley, the idler pulley for the cog belt, and a new belt (cog). i am letting this setup go for $300 obo.
Old Aug 6, 2002 | 12:40 PM
BlownBird's Avatar
one more....
Old Aug 6, 2002 | 10:44 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Can't really run a cog TPI setup without a bypass valve right?
-- Joe
Old Aug 7, 2002 | 01:37 AM
BlownBird's Avatar
Running a bypass is a good idea in any supercharged application, And is a must with a cog drive. If you are in need of a cog drive, you are at a point where a bypass should already be in use. Thanks for bringing it to the top!
Old Aug 7, 2002 | 07:01 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Don,
What are you going to use instead of the cogs?
What RPM will they be spinning Vortech. I am interested.
Old Aug 8, 2002 | 05:03 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
I am interested also
Old Aug 9, 2002 | 10:25 AM
BlownBird's Avatar
The cogs are still up for grabs. The crank pulley is a 75 tooth and the s/c pulley is a 30 tooth. Impeller speed will be...
50025 @ 5800
51750 @ 6000
53475 @ 6200
56062 @ 6500
(These calculations are fot the V1-V9 s/c units)
I have recently had another set of custom pulleys made by ASP that incorperates a vacuum pump, and utilizes a 50mm cog drive, that is the only reason I am selling this setup. I have almost $1000 into the new setup, and need to ofset the price a little. Thanks, Don B.
Old Aug 9, 2002 | 10:26 AM
bbunting's Avatar
Car: 1990 IROC Z
You have mail
Old Aug 9, 2002 | 01:26 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Don, drop me an e-mail as soon as you get this. I've been trying to get in touch w/ you. thanks Justin
Old Nov 13, 2013 | 03:23 PM
Car: 1987 GTA
Re: Cog pulleys for Vortech
11 years later.. hope all is well/
you got any pulleys or cogs laying around?
I know you constantly switch stuff up..
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
