Help me identify this turbo motor
Old Oct 3, 2002 | 08:32 PM
wes2k3's Avatar
I went to look at a 78 Z28 today. I popped the hood and what do I see, a 4 bolt main 350 with a turbo charger!!! So what is it. It is a regular 350, the driver side manifold runs under the motor into the passenger side manifold, then the turbo bolts to the passenger side manifold. The turbo takes air from under the carb (which sits where it would on an NA motor) and then pushes the compressed air into the manifold again. The turbo makes NO boost until you stomp it. Then the boost guage hops up to about 9 PSI and you have to hold on!!!. Does anyone know what this motor is or if I should buy it???????
Please help!!!!!
Old Oct 3, 2002 | 09:55 PM
Bobalos's Avatar
My guess is that it has a Turbo TA motor in it. I dont think that GM put those motors into Camaro's. if in fact that is the case then you have a poncho 350, I dont think that stuff will fit a Chevy motor, because of bolt paterns.
BW
Old Oct 3, 2002 | 10:30 PM
wes2k3's Avatar
It's not stock. No it is not a turbo 301 setup. The turbo does not sit on top of the intake like the 301. It sits right on the pass. side exhaust manifold. It is some type of vette setup.
Old Oct 3, 2002 | 10:40 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Its probably one of those aftermarket rajay kits you find on ebay now and then.
Like this: http://cgi.ebay.com/ebaymotors/ws/eB...tem=1864135070
This http://cgi.ebay.com/ebaymotors/ws/eB...tem=1865265724
Manifold alone http://cgi.ebay.com/ebaymotors/ws/eB...tem=1865095550
Old Oct 3, 2002 | 10:49 PM
wes2k3's Avatar
Yeah that is what it is. Are they any good? Should I buy it?
Old Oct 4, 2002 | 08:15 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
sounds like a rajay or accel single kit.
Old Oct 4, 2002 | 10:44 PM
wes2k3's Avatar
I know it's a rajay after looking at it again. Any info on this? Is it a good system? should I buy it?
Old Oct 6, 2002 | 10:57 AM
wes2k3's Avatar
Come on guys.
Old Oct 7, 2002 | 12:46 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Ive seen them make decent power, if the turbo or the motor is shot, or has one foot in the grave with the other kicking dirt, then you may be buying a headache. from your description it sounds healthy, if its not too expensive then it may be worth it.
Old Oct 7, 2002 | 02:21 PM
Nick89TA's Avatar
Here is a picture of the Martin/rajay kit on my 77 vette
https://www.thirdgen.org/techbb2/sho...threadid=36550
The car drives ok, but I have no track times to tell you. The throttle response is a little slow, and it is in need of a good tuneup. It was put on a stock 180hp L48 engine with 882 heads, and the kit definitely gives the car a little more on the top end. I have some plans to change/port the heads, cam it, and rebuild/get a new turbo. Ask for service records so you can find out if the turbo has been rebuilt recently. Later, and good luck
Old Oct 7, 2002 | 09:15 PM
wes2k3's Avatar
Yeah that is exatcly what it is, but yours is cleaner . So this would probably be a bad choice for a driver (I'm only 17, can barely afford the insurance on one car let alone two). I'm not against working on it, but it looks a little troublesome. This one has the valves to bypass the turbo as well.
Old Oct 10, 2002 | 10:59 PM
wes2k3's Avatar
Bump. I really need advice.
Old Oct 11, 2002 | 07:55 AM
mygrain's Avatar
If it runs good then I say buy it. How much does the seller want for it?
Old Oct 12, 2002 | 02:26 PM
wes2k3's Avatar
$3500 is the asking price. It is probably worth $2500. It has those gay Hurst T tops . And there is some rust, oil leaks and it need a water pump/exhaust.
Orr89RocZ
Apr 25, 2016 08:28 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
86White_T/A305
Aug 17, 2015 12:16 AM
