Cheap turbos
Old Jan 3, 2003 | 12:12 AM
87transam5.7tpi's Avatar
Cheap turbos
I've done lots of searchs and everybody says to use garret t3 turbos for a TT setup. I'm looking at only spending bout $1000 on all parts if possible. is there any other cheaper alternatives. thanks
Josh
Old Jan 3, 2003 | 07:00 AM
Guido's Avatar
Car: 2000 Trans Am
www.ebay.com
Old Jan 3, 2003 | 02:58 PM
ya I"ve looked on ebay. what I meant was everybody is tell ing me to get 2 garret T3's. on ebay they are around 400-500 used. is there any other alternatives? like I said this is lower dollar project too. thanks
Josh
Old Jan 3, 2003 | 08:58 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Junkyards. I got both my .60/.63's from the junkyard for less than $100 total. One needed a new cartridge, which was $125 off ebay. Keep looking, you'll find something.
Old Jan 6, 2003 | 08:34 AM
WickedTwinTurbo's Avatar
Go to turbobuick.com and post for stock GN turbo in the parts wanted section. you may get lucky you should be able to find it for around $150-300.
Godluck
Prasad
Old Jan 7, 2003 | 07:00 PM
gtaguy87's Avatar
Car: 1998 Ram Air Trans am
Engine: Ls1
Transmission: 6 speed manual
Turbos for an 87 305
I was wondering where you got the turbos for your gta and how much they were. Do they give you much more power or is there a lot of lag? Im debating between supercharging and twin turbo, trying to get some figures on HP increase and cost ratio.
Old Jan 7, 2003 | 08:18 PM
MdFormula350's Avatar
maybe the ones off of ford thunderbird turbo coupes or svo mustangs.
Old Jan 8, 2003 | 08:17 AM
I have two Hifi 60-1 turbos with P trim from Turbonetics they are around $700 each. I also have .59 a/r 4 bolt exhaust housing, this plays a big role in your spool up. Bigger the a/r number is more exhaust you need for spool up.I have no problem spooling up because I have a 3000+ stall converter and a trans brake. If it is possible, stick with a single turbo setup instead of twin. It all depends on what you goal is, 11's or 10's single turbo(good size) is more than good enough. Talk to all big turbo guys, they will tell you a single one is better than twin at least that is what Harry told me from Precision Turbo & Engine.
Good luck
Prasad
Old Jan 8, 2003 | 08:46 AM
Guido's Avatar
Car: 2000 Trans Am
i chose single because there are less components to connect and anywhere i want to race, frowns on twins as opposed to a single.
Old Jan 8, 2003 | 01:02 PM
gtaguy87's Avatar
Engine: Ls1
turbo
Is there a part number for that turbo and what kind of other stuff do you need to hook up and do you think a turbo is worth the money compared to a supercharger
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
cheesehomer
Dec 31, 2015 08:48 AM
bjpotter
Oct 4, 2015 07:48 PM
Damon
Sep 26, 2015 04:29 PM
