Procharger install help- GTA
Old Apr 1, 2003 | 11:10 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
1. HITHERE read the part that says "relocate the cruise diaphram to the rear of the shock tower". Um.. How exactly do you do that when the master cylinder is right there and the only spot that is left is the place where you mount the FMU? This is retarded.. If anyone's got better instructions or hints/pictures, HITHERE'd really appreciate it.
2. When HITHERE lowers the charger to the bracket it hit my fuel line from the pump? Is this normal? should HITHERE just bend it backwards?
Thanks in advance.
/N.
Old Apr 1, 2003 | 11:28 PM
87transam5.7tpi's Avatar
just send that baby ot me and HITHERE'll install it and let ya know what to do :-D No you should be able to just bend the fuel lines as long as you aren't restricting they're flow and the cruise thing you can move anywhere as long as you don't kink the line.
Josh
Old Apr 1, 2003 | 11:57 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
HITHERE know HITHERE can place it anywhere. HITHERE just cant find HITHERE good (any?)spot!
HITHERE'll let you guys know when HITHERE have tested it, hopefully its going to be fast.........
Old Apr 4, 2003 | 06:37 AM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
LOL. I wondered where to put the cruise actuater also. It's on the floor of my garage. the fuel lines hit my charger also so I installed braided lines up over the back of everything. Also didn't like the pos air filter housing they give for the back of charger, so I am currently designing my own. Where did you put your horn?
Old Apr 5, 2003 | 10:15 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Hi...
I still havent found any good place for the cruise control.........
The horn: I put it under the "battery" next to the Vacuum "ball" i'll post a pict. on monday...........
My installation is going to wait I'm going to USA on vacation....
Oh..I also need the replacement power steering pipe, where can I get one?
/N.
Old Apr 5, 2003 | 10:22 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
My ATI kit came with the Power steering lines.
I located the horns under the front of the car and bolted them to the flat plate that is between the bumper and the engine bay.
I located the cruise control to my garage!
Don't see any good place to install it????
I unbolted the metal fuel lines from the bracket at the front of the engine and this gave them better movement.
Hope this helps.
Say HITHERE, do you know Uffe? He is a fellow list member on the 1989 TTA newsgroup.
Old Apr 6, 2003 | 11:51 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I bought my kit used so I gues the power steering line still is on the other car.....
I dont want to put tne cruise control i nmy garage.....and YES I know Uffe.......He has a Buick regal now too......
/N.
Old Apr 7, 2003 | 11:36 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I found a place to mount it yesterday. I placed it on the strut near the brake booster. I modified the bracket some, I'll try to post a picture of it tomorrow!
/N.
Old Apr 8, 2003 | 11:40 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Here are the pics.
Crusie control.
Old Apr 8, 2003 | 11:41 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
One more....
Old Apr 9, 2003 | 11:45 AM
roadracinGTA's Avatar
I also have a GTA w/ a procharger, My installation of the C.C. looks almost the exact same.... I rerouted the fuel lines near the area where the washer fluid res. was. I am planning on redoing the fuel lines w/ braided lines....
I have the 3 core intercooler and it hurt the cooling system quite a bit. I am finishing an engine swap and plan on mounting the IC behind the bumper w/ some custom ducts built into the bumper. I also scraped the AC system for less restriction to the radiator
Old Apr 9, 2003 | 04:18 PM
88GTAinRI's Avatar
Engine: Blown 355
Wow. Nice to see and hear about all the boosted GTA's. I have no plans on adding the cruise control back into the car. I will put it in storage with the rest of the parts that I have removed from the car.
Old Apr 10, 2003 | 06:40 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Yeah, thats where I put mine.
The_Phoenix
Feb 4, 2016 07:10 AM
theurge
Aug 21, 2015 12:46 PM
djmarch
Aug 19, 2015 12:07 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
bryan623
Aug 10, 2015 11:33 AM
