The Ultimate Power Adder
Old May 5, 2003 | 01:51 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
You gotta love e-bay
What do starter motors rev at? Like 3000 rpm? What do turbos rev at? Like 250,000 rpm! I'm absolutely speechless! Part of me wants this to work, but the other part wants to start shooting stuff because this is sooo stupid.
Old May 5, 2003 | 02:15 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Wow. interesting concept.
Must have one hell of a charging system.
Old May 5, 2003 | 09:56 AM
Guido's Avatar
Car: 2000 Trans Am
LMFAO!! That is hilarious! Interesting but scary.
Old May 5, 2003 | 10:25 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
hahahaha, i needed that, i am having a bad day at work LMAO, that is too funny.
on second though.... i am good friends with one of the leading designers of brushless electic motors, what kind of RPM and power would it really take to spin a turbo fast enough to be effective?
Old May 5, 2003 | 07:00 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
it isn't nessisarily the power required to spin a turbo, but power needed to increase the pressure.
after doing some quick calculations....with a temp of 40 degrees, flowing 300 cfm and doing 10psi of boost, it would require a turbo to produce 53.92 hp at 100% efficiency. so an easy 60 hp for a "low boost" turbocharger.
i just had a thermo exam earlier so i think my math is right, but tell me if i am wrong
Old May 5, 2003 | 08:45 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
That's just silly. How much boost could you possibly get from a starter motor spinning the impeller? How about an oiling system? Starter motors are not designed to be on all the time, the motor would burn out in no time, then what? Grind all that TIG off and weld a new motor on?
Old May 5, 2003 | 08:49 PM
Car: 1985 Z-28
Engine: a big one
it is definately a cobbled together piece.
look somebody actually bid on it.
Old May 5, 2003 | 09:06 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Old May 6, 2003 | 04:27 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Old May 6, 2003 | 10:39 AM
Car: 1985 Z-28
Engine: a big one
actually, i wonder if the engine will actually suck in so much air that the compressor will actually drive the starter
Old May 6, 2003 | 10:55 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
LOL- then you could use it as an auxiliary alternator! (yeah right)
Old May 6, 2003 | 01:52 PM
Car: 1985 Z-28
Engine: a big one
i wonder if the starter rotates in the right direction?
Old May 6, 2003 | 02:02 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Isn't that just an impeller? How short yellow bus of the seller.....
Old May 6, 2003 | 02:08 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
that woul be hillarious to see it blowing (poorly) out of the inlet now wouldnt it - lol
Old May 6, 2003 | 05:59 PM
Nick89TA's Avatar
Guys guys, it's obvious what this thing is meant to do. When your car is sitting at idle your throttle blades are closed or almost closed. This jobbie just pressurizes the tube between the turbo and the throttle body. Sure your idle will go up a bit, but imagine... you can have like 15 psi of boost in that inlet tube. Until you step on the gas that is. And bog the engine. Crap, i thought my idea was going somewhere too.
Old May 7, 2003 | 08:20 PM
Car: 1985 Z-28
Engine: a big one
maybe it is an "active" version of that tornado thingy you put in your air intake to do whatever the hell it does.
Old May 8, 2003 | 11:18 AM
a73camaro's Avatar
No prob! Just reverse polarity!
What I find fricken' hilarious is that 5 separate people bid on that "power adder".
Numbskulls!
Old May 8, 2003 | 01:12 PM
Car: 1985 Z-28
Engine: a big one
250 bucks for that wonderful piece of crap... i should make some and sell them, i would have my car done in no time.
Old May 8, 2003 | 01:21 PM
Nick89TA's Avatar
Numbskulls!
For a real laugh, go to the bidders feedbacks and see what the last items they bought were. Here is an example One of the bidders bought this.
1986Z28OWNER
Dec 13, 2015 10:19 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
