NOS leaking over time!
Old May 8, 2003 | 11:03 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
I mounted my NOS bottle back where the spare tire was installed. I have the NOS branded remote bottle valve. The bottle over time leaks out. Does anyone have any suggestions in sealing the remote valve to the bottle? It has a plastic style gasket in the bottle valve.
thank you,
Mark
Old May 8, 2003 | 11:30 AM
a73camaro's Avatar
Retighten all your lines and use a sprayer with soapy water on all the fittings to find the possible leak.
Old May 8, 2003 | 01:26 PM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
I know where it is leaking. It is leaking where the bottle valve attaches to the bottle. I was just wondering if anyone is running into the same thing and if so what did they use to seal the fitting?
Teflon tape, pipe dope, or a new plastic washer each time they fill the bottle??
Mark
Old May 8, 2003 | 02:54 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
never use teflon tape, only liquid teflon paste.
Old May 8, 2003 | 03:39 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, I had the same problem. I filled the tank and put it in my wifes wash tub and checked it like you would an inner tube and sure enough the bottle valve was leaking. I did not want to change the bottle valve so I bought a new plastic washer and an elect. valve. Now I leave the bottle valve open all the time. I think the new plastic washer did the trick.
Auggie
Old May 9, 2003 | 03:36 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
how long is it taking to leak? overnight?
Old May 9, 2003 | 11:21 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I weighed my 10 lb. bottle that I had filled a month ago and there is only 6 lbs. left. Where did you get the plastic washer. What size is it?
Old May 9, 2003 | 11:55 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you only lost 4 lbs in a month of having the main valve open the whole time? that is actually awsome.
Old May 9, 2003 | 11:58 AM
Auggie's Avatar
Well, I bought my last plastic (teflon) washer (#16210NOS) when NOS was NOS but they were bought out by Holley. My bottle would leak around 1# a week. At $40 a bottle I fixed that in a hurry. Here are some numbers.
E-mail = NOS@holley.com
Tech Ser. = 1-714-546-0592
Fax = 1-714-545-8319
Auggie
Ps: Like I said I also have a "Remote Bottle Control" that lets me turn the bottle on or off from the drivers seat. So I just leave the bottle valve on all the time and shut off the remote bottle control solnoid until I need it. Hasn't leaked since.
Old May 9, 2003 | 03:38 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
That's the same thing I was thinking. I'm sure mine leaks that much.. I'll never know..
Average time for a 15lb bottle to live is about a night, MAYBE 2.
Old May 9, 2003 | 05:11 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
No, the valve is shut. The bottle is not on the car and it is in the garage waiting to go onto the car. I really think that it the washer under the valve.
Old May 9, 2003 | 05:24 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
ok I see
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
