the Blower cam i ordered, opinions?
Old Nov 25, 2003 | 07:30 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
well, it's too late to go back now, because i had my engine guy talk to his guy at Lunati,... this is the cam they will grind for me,. and this is what i got: 220/230 @.050 460/480 lift. 114 LSA. It's in the same ballpark as the ones you guys recomended, and my heads flow pretty good, so it should be fine,.. i went 114 like you guys said. Anyway, i trust Lunati, I'm not to sure why they went w/ such a large spread on the lift(and relatively low lift),.. but i guess it'll be fine. i have a feeling you guys may say something about the lift. maybe i got a good recomendation,.. maybe not, but it should work fine. any comments? please no bashing.
Old Nov 25, 2003 | 08:20 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Sounds decent, the lift is a bit low from what i would have expected, is it roller or flat tappet?, but it may get there quick and spend a lot of time around peak lift. As for the wide spread betwen the lobes, it's fairly common for a cam designed for blowers, extra mixture in means more exhaust to get out. Lotsa factors come into that though. Let us know how it works, it'll be interesting to see.
Old Nov 25, 2003 | 08:22 PM
Car: 1987 GTA
yeah, who knows. I am just assuming that it won't be a "bad" cam. Maybe it'll be great, maybe it won't be as good as some of the other grinds,.. but it should work pretty well with the computer. can't i up the lift with 1.6 rockers if necessary? thanks
Old Nov 25, 2003 | 08:50 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
use 1.6 rockers if not already, should make good power and be very streetable
Old Nov 25, 2003 | 10:20 PM
Car: 1987 GTA
yeah, i was gonna run it w/ the 1.5's at first and then bump it up to 1.6's maybe,.. have to see if my heads and springs can take it.
Old Nov 26, 2003 | 12:04 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You need'nt have bothered with a custom Lunati grind for this
Could have just bought a Crane HMV278-2. Its and off the shelf grind and very blower friendly.
specs are 278-290 222-234@.050" .467/.494' 114LSA.
A very sweet street blower cam.
Could have saved the extra cost of a custom grind.
www.cranecams.com
Cam Specs
Old Nov 26, 2003 | 07:36 AM
Car: 1987 GTA
well, atleast i know i'm in the right ballpark,. i like lunati, and i am getting a deal on it, because my machinist gets them cheap. he ordered it for me,.. should be cheap, and this way i know its right.
Old Nov 26, 2003 | 10:08 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
With your heads Id start out with 1.6 rockers...
will put you at 490/512 lift which is still on the safe side for sure...and still will have manners on the street as well...
Old Nov 26, 2003 | 10:33 AM
Car: 1987 GTA
I thought anything over .500 lift, the springs may need to be changed.
Old Nov 26, 2003 | 12:21 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
depends on the springs....Since you have aftermarket heads you are probably fine.... Trick Flow would be able to tell you...BUT typically I would buy the springs that are specific for my cam anyway...verus trying to buy a cam thats right for my springs...because springs are cheap...
Old Nov 26, 2003 | 04:20 PM
Car: 1987 GTA
yeah, i gues i'll do baseline runs w/ the 1.5's and then I can upgrade to 1.6's and worry about the springs then,thanks
Old Nov 26, 2003 | 04:22 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
That cams almost identical to the Comp Cams 276HR-14 #08-305-8 With 220/230 @ 50dur and .510/.510 lift and 114 lsa.
Thats the cam I plan on useing with my setup. Thanx now I am abit more confident that it will work fine
Old Nov 26, 2003 | 08:53 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
if you have the base tfs 195 heads your good for 520 lift
Old Nov 27, 2003 | 09:54 PM
Car: 1987 GTA
I have TF aluminum "twisted wedge" 2.02 66cc heads, if that helps,.. i got them 8 yrs ago.
Old Nov 28, 2003 | 12:09 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
how come there are no solid rollers in this range? also why no huge lift cams even in roller?
Old Nov 28, 2003 | 03:48 AM
89ProchargedROC's Avatar
Justin, sounds like a nice cam.
If you are interested i have a set of double crane valve springs that are good for up to .550
i was going to use them on my .515/.515 cam
let me know if you're interested
i'm not asking a whole lot
Old Nov 28, 2003 | 12:25 PM
Car: 1987 GTA
yeah i am interested,.. are they new? how much and will thye fit the trick flow twisted wedge design,..don't know if there is a difference. I don't know jack about heads yet. thanks email me.
Old Nov 28, 2003 | 09:44 PM
Justin, check your PMs. I tried emailing you but it bounced me
Old Nov 29, 2003 | 12:28 AM
Car: 1987 GTA
i sent you a message
Old Nov 29, 2003 | 09:16 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I think he has a great combo; SuperRam with a 220/230 is perfect for those heads... add the intercooled boost and you have a pretty crazy setup if you ask me.
I think his injectors are too small though, 26Lb/Hr on 12 PSI of intercooled boost? And hes using an FMU... I can hear the fuel pump already.
Old Nov 29, 2003 | 11:13 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I agree.. 26ers are on the small side.
My 305 with 12 lbs, ran with 30's, and I was running out of DC with those.
New motor will run 36 lb injectors, and it might need even larger injectors yet.
BW
Frozer!!!
Jan 19, 2024 04:55 PM
soarestransam
Sep 1, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
mhatfield 14
Aug 15, 2015 10:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
