Nitrous ?'s
Old Dec 13, 2003 | 10:42 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
Nitrous ?'s
i just bought a nitrous kit and i was wondering what would be safe? i have a 170,000 miles and mods and car in sig. i have the bottle and line fittings and sloenoids its not a "kit" i bought it in pieces but its all the same. and i need to find a place to get a tbi nitrous plate. and i was told by people that they have had 100 shot with about the same miles and have had no probs. so how much is ok i was thinking a 50 or 75 shot wet. but any advice would help. i have talked to people that know alot about nitroue and think i can run a 100 but u guys know more about my car then they do. thanks
Old Dec 14, 2003 | 12:14 AM
rustbird's Avatar
Car: 92 firebird
Engine: A small block something?
i gave my old 305 tbi 150 shot with a good fuel pump,injectors,ect ,ect
i got a double fogger with a tbi intake ill sell got a chip for it and everything you need.
name a price??? kit has one bad soilinoid
all wirind and n20 chip included
btw i got jets to make a 75,90,125, 150,
i was just tryin to fry my 305 before i put the other motor in.toke the 150'r like a soldier so it never happened
Old Dec 14, 2003 | 02:17 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I'd say assuming that the fuel pump is up to it, and the rest of the engine is sound then 100-125 should be safe. If it's burning any oil fix that first, you want no detonation.
Old Dec 14, 2003 | 03:49 AM
Car: 1992 Firebird
the valve guides are bad it smokes when i start it but thats it. no smoke when i drive. it seems like a pain just to change the valve guides and the stuff up there and still have 170k on the bottom end but if i need to so i dont go boom then i guess i will have too
Old Dec 15, 2003 | 03:10 AM
stevedave454's Avatar
Car: 91 S10
i'd say just make sure you have a good high volume fuel pump, then have fun with 100-150 shot
Old Dec 15, 2003 | 03:06 PM
Car: 1992 Firebird
how much nitrous can the stock pump handle?. and what kind would i need to get to flow for a 100 shot? thanks
Old Dec 15, 2003 | 03:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
my thoughts on this:
if i were doing it, i would get a carb intake and run a carb plate setup with a TBI adaper on top... my reasoning is, IMO you would get more even flow to all cyls... plus it cant hurt.. not needed, but its just how i would go with it....
as far as the stock pump, well, thats kind of a gray area.... at thoes miles, the pump may be just bearly flowing enough for the stock setup, or it may be working great and support +100 hp... you have no real way of knowing...
unless this is a "lets blow up a 305" exersise, id replace the pump before i ran any N2O thru it..... but thats my extreme saftey side point of view on it...
and personally, i wouldnt run over 100shot if i wanted to keep the motor.
Old Dec 15, 2003 | 08:58 PM
Car: 1992 Firebird
where can i get a high flow pump?
Old Dec 16, 2003 | 01:48 AM
IROCKZ4me's Avatar
Nitrous express says a stock pump will take you to 125 HP safely.
That is assuming that it is in good condition. If your pumps condition is in doubt a new stock replacement (AC Delco or Walbro) should be sufficient for 125 HP.
Old Dec 16, 2003 | 08:01 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
id also add, that if you're going to put a stock replacement pump, you can get a walbro255 for about the same price, and somtimes less if you find a deal online....
Old Dec 16, 2003 | 12:16 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I agree, dont trust the stocker
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
