Got the chance to run the new motor!
Old Feb 24, 2004 | 11:21 PM
NOSFEDGTA's Avatar
I got a chance to run my new 406 last week and the results are great!!! On motor it went a 6.94 in the 1/8th @102mph I sprayed it with a 150shot and it went 6.30s @108. I am still trying to get my converter right. I have tried 2 combos so far and I think this last one will be the right one for what I want it to do. The last 2 were just to tigh out of the hole. In all I am satisfied so far. I will be spraying 200 then 250 in a week or 2 . I am looking for some 6.0's.
Car weighed 3417 with me in it and a full bottle. motor is a 406cid with 12:1 comp, afr heads, custom solid roller, action plus "tall intake and a custom built quickfuel 950 cfm carb
Old Feb 24, 2004 | 11:38 PM
MdFormula350's Avatar
:hail: :hail:
Old Feb 25, 2004 | 11:27 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Looking at a mid 9sec pass. Good work. I've enjoyed reading up on your setup and following your progress, keep us posted.
Old Feb 25, 2004 | 02:31 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
damn man thats flying. Hows it hookin up? Your spraying out of the hole right? what are your 60's like?
Eric
Old Feb 25, 2004 | 03:32 PM
NOSFEDGTA's Avatar
Thanx, I hope to have my converter issues solved soon. I will keep everyone posted. I am loking for some 9.50's @145mph out of it.
Old Feb 25, 2004 | 03:34 PM
NOSFEDGTA's Avatar
Eric
I went a 6.38 and was spinning out of the hole. I run some 28x9's and need to step it up to some 28x10.5's to get it right. My old 350 would 60ft 1.44 and this new setup is making lots more power so I ma trying to get the right converter and tire combo. the best I can get out of it is a 1.50
Old Feb 25, 2004 | 04:39 PM
92stealthramz28's Avatar
Car: 92 Camaro z28
Engine: 427 sb
Transmission: th400
Axle/Gears: 9"/4.30
Nice time. What afr heads r u using?
Old Feb 25, 2004 | 09:08 PM
NOSFEDGTA's Avatar
afr 210's flow 300 int and I had the exhaust fully ported. The exhaust actually flows 230cfm
Old Feb 26, 2004 | 11:41 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Sweet times Drew..shawn scared yet?
Old Feb 26, 2004 | 02:54 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Steve
Old Feb 26, 2004 | 07:30 PM
NOSFEDGTA's Avatar
Lest just say he put the 2 stage on it!! we ran on motor sunday and he could not pull on me at all!!!!! He runs a 8in 5300 stall so he would always out 60ft me 1.48 on motor!!! i am running a nitorus stall so I would have to tree him to win, but he is damn good on the tree!! for kicks I redlighted with a .487 and guess who could not run me down we came back around and Jimmy said damn you know whats bad sean, drew even started to pull away about the 600 ft mark I just smiled and said when we juice run its on!
Old Feb 27, 2004 | 01:53 AM
83 Crossfire TA's Avatar
Re: Got the chance to run the new motor!
Nice times!
One of these days I'll figure out how some of you with what should be a relatively heavy car manage to get them so light. I've owned a few 3rd gens now and I've never managed to get one under the low 3400# range without empty (and I'm about 300# so my race weight is always over 3700-3800#)
Old Feb 27, 2004 | 11:56 AM
NOSFEDGTA's Avatar
That weight is with an 8 point cage, full spohn suspension, a moser 9in rear, and me weighing in at 230. I have removed the from bumper support, rear bumper support, rear speakers, added a fiberglass hood, aluminum heads, took all the stuff out from under the carpet front and rear, skinnies in the front and draglights in the back and I still have the tock 40lb wing on it as well. It weighed 3185 without me in it.
My friend Seans weighs 3218 with him in his and it is a 86 camaro z-28.. It weighs 2998 without him in it.
Old Feb 27, 2004 | 04:08 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
I'm usually between 3520-3550(with me in it at 250lbs, probrobly right around or just under 3300 empty)depending on how much gas and what tools I brought with me to the track and my car has similar mods such as the bumper supports but I run stock GTA wheels with 245/50R16 up front and 26x11.5-16 ET Streets out back.
But my real reason for posting, the rear wing really weighs 40lbs? Didnt know it was that heavy, wonder how heavy the glass replacements are? Makes me wanna ditch my wing scince it's starting to look like crap anyway.
Steve
Old Feb 27, 2004 | 05:16 PM
NOSFEDGTA's Avatar
Steve
The nice thing about the gta wheels is they are light compared to any other wheel out there. Besides weld, bogart, etc. The rear wing is probably pushing 30-40 lbs easy. Its a solid rubber piece. The aftermarket fiberglass one is 7-10 if I remember right.
jhawkeye
May 25, 2022 06:33 PM
bryan623
Mar 22, 2021 06:43 PM
Vintageracer
Jan 10, 2020 05:33 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Elliswon
Aug 10, 2015 12:33 PM
