Twisted Wedge Heads?
Old Mar 18, 2004 | 04:24 PM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
iv'e heard that i can't use my tric flow, twisted wedge heads with a supercharger. is this true??? if so what about nitrouse?
Old Mar 18, 2004 | 05:08 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i have them on my car works ok with my setup upgrade the spring.
Old Mar 18, 2004 | 05:10 PM
Engine: 5.8Ltr 356
what kind of supercharger are you using? im lookin into vortec.
Old Mar 19, 2004 | 12:43 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Re: Twisted Wedge Heads?
who said that
i call
Old Mar 19, 2004 | 09:25 AM
Raiden's Avatar
I do not see why you could not use them with a blower???? What issues do you think you may have? One suggestion, If you are using over 8psi, get your block setup so you can put the rubber O rings around each piston! I was blowing gaskets left and right once I got over 8psi, then, went to the O ring method and it solved my issues.
Old Mar 19, 2004 | 03:02 PM
Engine: 5.8Ltr 356
there was an issue in High Performance Pontiac where they discussed that issue on old GTO's. they used a similar method with steel rings around the cylinders to help stop from blowing the head gaskets all the time.
Old Mar 19, 2004 | 03:26 PM
Raiden's Avatar
Yea, I am using thoes gaskets currently. I think theyare felpro 1010's? Not sure? But they work awsome!
Old Mar 19, 2004 | 11:34 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Just so you know, if your blowing head gaskets at only 8psi you most likely have a tuning problem thats causing detonation. Without detonation the stock head gaskets should hold up fine. Hell mine hold up well at 27psi and I have 1 less bolt per cylinder.
Old Mar 20, 2004 | 01:04 AM
Raiden's Avatar
I was running 14psi, then had the problem of blowing gaskets. Got the right gasket's and never again!
Old Mar 22, 2004 | 05:03 PM
antoine's Avatar
i am running a paxton and i use felpro headgasket 1010.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
