want nitrous, but don't have hood clearance ? here you go
Old May 17, 2004 | 01:55 PM
MIKE 1985's Avatar
Old May 19, 2004 | 12:19 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Looks pretty good. Hopefully it seals up good.
Old May 19, 2004 | 10:26 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Am I the only one who sees a problem with that design?
Old May 19, 2004 | 10:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i was thinking the same thing.
nitrous in one bank, fuel in the other....
Old May 19, 2004 | 11:52 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
there are two tubes there or one?
Old May 19, 2004 | 12:24 PM
That too but that is not the only problem I am seeing. I am thinking more along the lines of nitrous/fuel distribution problems since the bar is not running parallel with the intake runners.
Old May 19, 2004 | 05:49 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
There has to be 2 bars, or this wont last 2 seconds.....one ultra rich side, one ULTRA lean(BANG) side
How do you take it off, it looks like the bar goes through the plentum divider?
Old May 20, 2004 | 09:42 AM
MIKE 1985's Avatar
yes guys 2 bars , one for nitrous, one for fuel. Just like any other wet kit .
I have personally see plate kits set in the same configuration. I don't see a problem, i'll let you know by Monday how it works.
Old May 20, 2004 | 01:51 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
oh because in the picture it just looks like one spray bar
Old Jul 5, 2004 | 06:54 PM
biohzrd's Avatar
just wondering if it worked or not????
Old Jul 5, 2004 | 09:55 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I want to see pictures of the melted engine parts
Old Jul 6, 2004 | 10:49 AM
MIKE 1985's Avatar
I have only sprayed it on the street so far, it seems to work very well, the car ran 12.76 on motor i'll spray it at the track next month.
If you want to see melted engine parts, then blow your own stuff up.
Old Jul 6, 2004 | 10:55 AM
FLYNLOW92rs's Avatar
Is the other bar sitting in the package for the nitrous kit, because it sure isn't in the picture you posted above.......
Old Jul 6, 2004 | 11:47 AM
biohzrd's Avatar
cool.. let us know how it works. would like nitrous, but don't have the hood clearance for a plate so i'm very intrested in this.
Old Jul 6, 2004 | 12:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
http://images.google.com/imgres?imgu...3Doff%26sa%3DG
http://www.surfware.com/Images/i-wilson.jpg
http://www.holley.com/HiOctn/ProdLin...f05004NOS.html
hmmmm.
matter of fact, NONE OF THESE AFTERMARKET SINGLE STAGE PLATES HAS MORE THEN ONE BAR!! AHHH! EVERYONE IS GOING TO BURN UP THEIR MOTOR! AHHH! THEY'RE ALL SCREWED!
[/faux horror]
lmao.
so has anyone of the above posters ever held a single stage plate in their hand?
Old Jul 6, 2004 | 12:20 PM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
Have you ????? Every kit you showed that utilized spray bars had two of them. Take a closer look.
Old Jul 6, 2004 | 01:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
look again. i think that holley one had the best pic.
anyhoo, i have mine right here.
one problem.
it doesnt have any spray bars. (teh prize goes to the first person that can post the brand of plate system i have that doesnt have spray bars, lol)
Old Jul 6, 2004 | 01:52 PM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
I WIN!!!!!!!
Old Jul 6, 2004 | 01:54 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by screamin' 85 z
I WIN!!!!!!!
lol yup.
not that big kit, but yea, its NX.
Old Jul 6, 2004 | 03:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It is the best pic, and it clearly has 2 bars.
Old Jul 6, 2004 | 04:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
im not going to argue with the ignorant.
heres the last pic..
all pics found thru google in under 4mins.
Old Jul 6, 2004 | 05:36 PM
Car: '84 Trans Am
There is clearly two bars there. Even the description in that holley link refers to the spray bars in plural. I can take a picture of my sniper kit if you really want see.
Old Jul 6, 2004 | 06:15 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I know someone running that Holley kit, it has 2 spraybars. All those pics, 2 spraybars.
Do you think fuel that's under 50 PSI is going to hold up pushing against nitrous that's 1000 PSI in one spraybar?
Old Jul 6, 2004 | 08:03 PM
DIGGLER's Avatar
carb stuff here, pedro.... more like 7-10# fuel pressure.
jeremy
Old Jul 6, 2004 | 08:05 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
jeremy
"under 50 PSI" covers carb apps, spanky.
Old Jul 6, 2004 | 08:25 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
jeremy
No, hes right. ~50psi if FI only. :lala:
Old Jul 6, 2004 | 09:14 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Under 50 denotes all numbers BELOW 50. That would be negative infinity -> 49. Now 7, 10 and all numbers in between, are BELOW 50.
Old Jul 7, 2004 | 05:26 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
This now qualifies as the BIGGEST generalization I have ever seen.
Its like saying "where do you set your tire pressure" Umm, somwhere between negative infinity and 50 psi.
If the world worked like this, math wouldnt be needed and no one would ever be wrong.
Old Jul 7, 2004 | 12:25 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
It's not that general when you consider that it's going to be trying to push against nitrous that's 20 TIMES it's pressure. In this situation, it doesn't matter if the fuel pressure is 7, 25 or 50 PSI.
Old Jul 7, 2004 | 04:14 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
The only other fuel system that runs with a pressure well below 50 psi is TBI, and its rather rare to run a nitrous plate on TBI, therefore its a given that he was talking about CARBS. Not exactly a generalization, but thats besides the point since he's referring to the fact that 50 divided by 1000 is a significant number, much less 5 divided by 1000 in terms of pressure variance.
Old Jul 7, 2004 | 04:52 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
I'm glad I'mm a turbo guru and don't have to put up with this when I talk tech!
J/K
Old Jul 11, 2004 | 01:35 AM
5SIZ's Avatar
Car: 1987 IROC-Z
Last time I checked 50 psi was less than 1000 psi. Wich would also mean that 1000 psi has 950 psi more making the pressure 95% stronger... Now if 50 psi was pushing against 1000 psi what would happen, those that have a common sense will figure it out, the same concept goes for carbs with 7psi...7psi..1000 psi...yea um yea.
2 bars.
Old Jul 12, 2004 | 08:29 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
2 bars.
you would have either
A: Fuel bowls filled with nitrous or
B: a Fuel tank filled with nitrous
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Wife'sCar
Aug 22, 2015 01:46 PM
Randomtask2
Aug 13, 2015 01:57 AM
bryan623
Aug 10, 2015 11:33 AM
