Turbo Headers
Old May 26, 2004 | 12:56 AM
widow_maker89's Avatar
Turbo Headers
OK i have a question for all you guys. I doubt that it will get many results but... I have done much searching on the whole turbo manifold and turbo header subject. I have found many many pictures and a lot fo good resources but as of yet i have no schematics. I have an 89 Trans Am 350 TPI with a 5 speed. I currently have a serpentine system, but i can convert to any belt system nessecary. As for my setup i have 2 T-3 turbos. They have 57 trim wheels .63 Ar on the turbine side and one size larger on the compressor .72 i believe ceramic coated as well as the down pipes I am using dual 2.3 SVO intercoolers and dual blow off valves i will be utilizing about 10 lbs of boost. For fuel management i will be using the sy/ty system Hopefully i will use a water injection system but thats not for sure for now.... the engine is a L98 from a 91 Z28 aluminum corvette heads 8.3:1 compression ported TPI ported throttle body ported stock lower intake but again this post is actually looking for a twin turbo header layout i have access to mig tig smaw heliarc heli oxygen and oxygen acetaline welders an thinking of using stainless t304 or 316 mabey better as money permits. thanks for any and all help you guys can offer thanks in advance matt manglos
Old May 27, 2004 | 06:51 AM
So... nobody has the instructions with measurements to make headers... how about some suggestions on what kinda of material? grade of stainless or how thick of mild steel do i use come one people some suggestions would be nice.... thanks
Old May 27, 2004 | 07:41 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Nobody is really gona beable to give you measuerments. Your best bet is to buy the materials and goto town.
304ss is nice but if its outa your budget mild steel will be fine.
Your headed in the right direction. just need to look at a ton of pic's and deside what way you want to go.
here surf through the collection of pic's Ive accumulated when I was gona do Twins. but Ive since sold my two 60/63 T3's and went with one Large Single
http://www.cecoatings.com/images/oth...ens/TurboCars/
Hope this helps ya some.
Old May 27, 2004 | 07:46 AM
well thank you chris, i have looked at your collection extensively... i like the truck... diesel dragster lol thats cool out of curiosity do you know who made the log style manifold on you sight... one unfinished one finished with the turbo mounted and if i do use mild steel what wall thickness is acceptable... i think ican go for the stainless my car has been down a year while i got what i do have t-3's .63 ar turbine .72 compressor 57 trim wheel svo intercoolers... blah blah blah all just a bunch of talk till i make it come together i know... one could hope for measurements... not incredibly likely but it was worth a shot... again thanks for the reply
Old May 27, 2004 | 07:58 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Im gona assume you mean this picture
http://www.cecoatings.com/images/oth...demanifold.jpg
http://www.cecoatings.com/images/oth...incomplete.jpg
I belive that is DanW from here. I saved them long ago. Never heard anything more on that setup. I use to have all them pic's In named folders but I moved my site to a new server and just used my old back up files to reupload it all.
Old May 27, 2004 | 08:09 AM
those would be the ones, I am looking into the all out seperate runner header option but im not sure i want to take all the time and effort for the additional pain in the @$$ of routing it (it does take up a lot more room) and if i am working in stainless a lot more price, i am very experienced at all aspects of welding so no probs there cast is fun... and i considered going the way of a few others on this board but i just cant bring myself to doing that i mean no insult intended to those who have done it i am quite impressed with the result and its very ingenious but i like the more profesional look of the log style manifold done properly i considered ordering manifolds from banks but at over 700 a pair thats a lot of money.... i guess i jsut have to take mesurements and start up my own set only i will document steps and measurements so i can reproduce them did you ever tell me a good sidewall thickness for ss or mild? i considered an inconel alloy untill i saw what raw materials run OMG... anyways i ahve about everyhitng i need other than the manifolds and the fuel management i think i will run the sy/ty ecm and do some serious learning on the programming, mabey someone will be able to give me a good starter bin... i htink i may have one already if i can find it its a supercharge 12 psi bin that has been tuned.. might work as a starting point for me. DAN W i will see what i can find out... mabey there is hope yet.... Btw ceramicoating is totally worth it what is a rough cost to have turbo's headers and down pipes coated ? not looking for a real specific answer jsut a ball park. thanks matt
Old May 27, 2004 | 10:13 AM
Guido's Avatar
Car: 2000 Trans Am
700 per set is not bad. If you are looking into fabricating your own tubular headers, its going to get you close to that figure unless you have sources to cheaper materials such as flanges.
Good luck!
Old May 27, 2004 | 10:18 AM
i do have sources for cheap SS but 700 for a set of cast iron manifolds.... i could buy some really nice premade headers for around that price, not complaining just measuring up all my options b4 i spend anymore money
Old May 27, 2004 | 11:11 AM
nightrider87's Avatar
Is that L98 rebuilt? I'm just curious because i noticed you said that you put a set of aluminum vette heads on it and without a rebuild that would bump up your compression quite a bit rather than lowering it.
L98 aluminum heads have 58cc chambers while the irons have 64cc i believe.
Just trying to catch something you may have missed and even clear it up for me too
Old May 27, 2004 | 11:13 AM
2.5" OD x 0.12" WALL x 2.26" ID T-304 TUBE would this be acceptable or do i need a thicker wall.... this is t-304 and i can get it for 110 for 8' lengths
Old May 27, 2004 | 11:16 AM
to night rider yes, completely rebuilt, the signature is from the engine that was in it to begin with..... well the one i put in it but yes forged Crank LT1 rods forged pistons and ARP stud kitlow compression pistons but final ratio ends up at about 8.25:1
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
