My new HSR throttle body spacer. :D
Car: Sexy
Engine: Stock
Transmission: Slipping
When I installed my Stealth Ram, I had a problem with the throttle body linkage hitting the fitting on the fuel rail, found a good solution. Now I have a reason to hang out with the Power Adder guys.
Question: Would a HSR still suffer from fuel puddling on a wet nitrous kit like stock TPI?
Car: Sexy
Engine: Stock
One more question. Do the solenoids have to be mounted straight up (labels correct)? I have the mounted that way, was just curious.
Car: 1992 B4C 1LE
I have mounted many a nitrous selenoid "up-side-down" it does not effect operation. Here is one I did at our shop. btw I like your spacer and was considering using one I have just like it, that settles it.
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I ran into the same problem with an HSR install. I found you can also grind the brass fitting down enough to safely gain the clearance needed without making it to thin.
Car: Sexy
Engine: Stock
Thanks for the info.
I just hit the nitrous for the first time about 30 minutes ago, and I think my fuel pressure safety switch is cutting it off in 3rd gear around 4200 rpm. It was set to 35 psi, I turned it down to 32. What's a good safety pressure for efi?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Sounds like your running out of fuel, GM fuel pressure should be at around 44psi when on the pedal. Are you still using the stock pump?
Car: Sexy
Engine: Stock
Yeah, stock fuel pump. I have a 255 lph Holley pump sitting here, I just need to find someone to install it, because I sure as hell don't want to do it.
After turning the fuel pressure safety down it seems to run better now. I had the scanner hooked up and it was pulling 4-6 degrees of knock retard, 10 degrees peak. The O2 read ~930 mV the whole time, so I don't think I was leaning out. I zeroed out my WOT spark advance table and took 2 degrees out of the 90 kPa/3600 rpm+ area, but I haven't hit the button again yet.
I'm glad I did suspension first and got a window switch. Everyone was telling me I wouldn't be able to hook nitrous on the street. Here's a graph of the data. #1 is where I stalled up the stock convertor at the light, #2 is my typical second gear spin thanks to the shift kit, which I was shifting early. This is my first ever run on nitrous, so I have some decent knock retard, as shown by the pinkish line. The window switch is set to 3000 on/ 5000 off. When you shift early you can really feel when you come off nitrous, then it kicks back in and puts the smile back on your face.
Car: Sexy
Engine: Stock
Revision to last post: 12 degrees peak retard. And this is my first run on nitrous with the scanner hooked up, third run ever.
I guess when you're "On Probation" you can't edit posts.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 89 GTA
Well I wouldn't rely to heavily on your stock o2 but 930 mV don't sound to bad at all, might I suggest taking a little more timing out in the upper kPa area just to be on the safe side, 12 degrees retard is a fair bit.
Car: Sexy
Engine: Stock
Yeah, I know the stock O2 is useless up there, but at least it tells me "rich" instead of "lean". If all the lights went out on my O2 gauge I would've slapped that switch right off.
I pulled 7 degrees out of that area in PE mode (only time nitrous is on) so next time I hit it I'll take a look. I might try colder plugs, then a retard box if needed. I don't want to totally kill my high end when I'm not on nitrous, ya know?
anesthes - It doesn't matter. But I also can't change my sig. heh
Car: 89 GTA
You might want to look at getting one of craig's bin switcher items, then you can have a bin set for nitrous and one for normal driving.
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
