Compressed air to how much heat?
Old Jun 21, 2004 | 12:19 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Is there a graph or something that shows what the heat would be at XXpsi?
Example:
(100* ambient) + (compressed at 5psi) = 150* intake air
I'm trying to determine what kind of intercooler that I will need to air/air or water/air.
Thanks,
Daniel
Old Jun 21, 2004 | 12:40 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Temperature of the compressor outlet depends largely on the compressor's effeciency and the effeciency range you are operting the turbo in (think of compressor maps). I think McInnes Turbochargers book has some of those formulas.
Old Jun 22, 2004 | 02:12 AM
83 Crossfire TA's Avatar
You use the ideal gas law to figure out what the temp rise should be assuming that the compressor was 100% efficient, and then figure out the additional temp rise due to it’s actual efficiency. Make sure you do all the math in * R or you’ll get some really funky results.
Old Jun 22, 2004 | 07:13 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I have an excel file that can do this for you (if you have excel on your computer). All of the calculations are taken from the "Turbochagers" book mentioned above. Go to the 'Turbo Size' tab, simply change the boost level in the shaded cell, and look at T-ideal in the lower list of values. This is the temperature rise due to compressing the air. The other values in the shaded cells can be changed also, but they don't contribute to the ideal temp rise so for this it doesn't matter what they say. Put in your estimated compressor efficiency and then the T-actual cell will become accurate, or just put in your whole combo for the full scoop:
http://www.egr.msu.edu/~remondi2/Car%20Calcs.xls
(note: all temps are required and given in *F to simplify things a little)
Old Jun 22, 2004 | 08:46 AM
Thanks man.
I went to the book store trying to find that one, but Barnes & Noble didn't have it. I'm going to go to another one this weekend and try to find it. If not I will order it.
Thanks everyone.
Old Jun 22, 2004 | 03:28 PM
Car: I
Engine: Taunt
If you think you'll use it, get it. It's a great book. Another real good one that has a bit of a different approach is "Maximum Boost" by Corky Bell I believe. Your not going to find either anywhere for cheaper than amazon.com, and they are pretty quick with their standard shipping too.
Old Jun 23, 2004 | 08:57 AM
Thanks.
I'm loving the power adder board, people are much nicer here than in the TPI area.
Old Jun 23, 2004 | 08:22 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Lol, I think once I get the LT1 runnin', I may be frequenting this board soon too. You gettin' a S'Charger Maroon?
Old Jun 24, 2004 | 08:45 AM
I will be going with the twin turbo system. I have a really nice set of heads that would really like some extra air now.
http://www.bbsdesigns.net
You can see some pics when you get there.
Old Jun 24, 2004 | 06:09 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Is there any reason why that setup won't work for an LT1 in a thirdgen? If the stock manifolds will fit on an LT1, there can't betoo much difference between the LT1 setup and the L98 can there??
Old Jun 25, 2004 | 11:26 AM
The intake might be the only difference since it sits lower. You might need to customiize one.
Old Jul 1, 2004 | 04:29 AM
contactpatch's Avatar
Engine: sbc 350
Is there enough information in the ideal gas law to solve this
problem.? I would think that you would start
by assuming adiabatic compresssion, and using the ST diagram.
Or something like that, then adding more temp for compressor ineff.
Old Jul 1, 2004 | 06:05 PM
When you try to do the math you’ll find that the most of the ideal gas law stuff cancels out and you’re good. As far as the spreadsheet… I believe that we’ve had this discussion before, it’s nicely laid out but I don’t believe the results it gives for this is correct. I haven’t posted about it because I wanted to try to figure out why I was getting different numbers then it was but I haven’t had the time to sit around and actually look at it, but I’m pretty sure that we’ve had a thread about this before.
Todd84Z
Sep 4, 2015 08:02 AM
dyeager535
Aug 28, 2015 08:10 AM
86IROC112
Aug 21, 2015 07:20 PM
Dialed_In
Aug 20, 2015 01:45 PM
kyle5647
Aug 15, 2015 11:56 PM
