how lean should idle be 16:1 ??
Old Jun 26, 2004 | 07:28 PM
wjbecker's Avatar
Car: 89 gta
Engine: 5.7
Hi guys I put a procharger 9psi
on my 89 gta it works great.how lean is
too lean for idle??? I have @16:1
in open loop and i lowered it from 18:1
should i go to 15:1 or 15.5:1????
thanks in advance
Old Jun 27, 2004 | 01:26 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
14.7:1
Old Jun 27, 2004 | 03:43 PM
TexasLT1's Avatar
Car: '92 RS
As lean as you want and the engine can handle. 16:1 sounds way too lean though. I wouldn't go any higher than 15:1, but since its just idle, is there really a point to go any higher than 14.7? You're not going to gain anything by doing that.
Old Jun 27, 2004 | 05:01 PM
wjbecker's Avatar
Car: 89 gta
Engine: 5.7
thanks for reply
I have read posts in the past
that someone said a lean idle is desireable and I think ihave seen it multiple times. once my car goes into closed loop it modulates between 14.3:1
and 15.4:1 but it hangs around 14.7.
open loop hangs around 15.1:1 to 16:1.
I can adjust the maf to get closer to 14.7
but it runs and idles so good.
I will get it to 14.7 at idle to have something to compare to.
this car is a weekend daily driver
and I want it to be happy in all weather.
thanks
Old Jun 27, 2004 | 08:31 PM
25THRSS's Avatar
that is fine. Some cars only get around 17:1 afr during highway mode.
Old Jun 28, 2004 | 12:27 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Are you getting your numbers from a WB02 setup or are you just looking at what the scantool is putting out.
Old Jun 28, 2004 | 06:55 PM
wjbecker's Avatar
Car: 89 gta
Engine: 5.7
I am using a techedge wb02
it is very relyable so far --3 wks.
Old Jun 29, 2004 | 12:01 AM
biggtime's Avatar
I'm 14:1. Thats what my combo likes. You need to find what your engine wants. Different Idle speeds will dictate different mixtures.
Old Jul 2, 2004 | 12:43 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Big cam engines may like richer A/F at idle to stabilize it......
I think GM has richen up the idle some in the chip......
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
