Nitrous question (i did a search)
Old Jul 20, 2004 | 12:02 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
Ok guys, heres the deal right now i have a 350 with cast pistons so i cant run as big of a shot as id like to. So what im thinking is getting the sniper kit, and run about a 100 shot for now and it wont be on the street just a couple of times at the track. But my main ? is if i ever do end up building a forged motor, i was wondering if i just buy the cheater solenoids/jets if i can run the 250 shot using all the other sniper stuff? thanx in advance
Old Jul 20, 2004 | 11:02 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Why not just buy the cheater kit?
Old Jul 20, 2004 | 03:15 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
because my motor right now wont take the 150 (it probably will but id rather be safe than sorry if you know what i mean)
Old Jul 20, 2004 | 11:52 PM
Car: '89 IROC-Z
It says "150-250" because thats the jets it comes with... You can buy smaller jets and still use them with the kit just fine.
Old Jul 20, 2004 | 11:57 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
ok, cause i was looking and the solenoids are diff, thats all. so it just brought up some questions, now can i put the cheater jets in a sniper system?
Old Sep 10, 2004 | 01:44 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
so if i were to buy a wet kit that has a 125 jet can i just get a bigger jet and spray more?
Old Sep 10, 2004 | 02:17 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I can only speak on NOS brand parts since that's what I have, but all the jets are the same type, you just choose the size for the power and stick it in. As long as your solenoids can flow the nitrous/fuel it'll be fine. (And you have a kit that can change jets.)
Old Sep 10, 2004 | 02:50 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
good maybe you can help me some more
im going to buy a used system saturday. its a NOS brand wet kit but was a fogger system. the fogger wouldnt work on his HSr so he went with a plate. he said he has 75 and 125 jets for it but i want to spray more so would i be able to with just adding bigger jets (or is there something else i have to do like change soleniods??)
and can a purge be added if it originally didnt come with one. i really want a purge on it.
thanks!!!!!!!!!!!!
Old Sep 10, 2004 | 09:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
TTT anyone???? i also need to know if a nitrous kit would be worth paying 275 for without a WOT switch, fuel pressure safety switch, and purge.......
Old Sep 10, 2004 | 11:19 PM
Car: '89 IROC-Z
The problem is that most kits that they sell rated at like "50 to 125HP" have really tiny solenoids... You could probably go over a little but I wouldnt get carried away.
Old Sep 11, 2004 | 01:23 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well what exactly does the soleniod do? i thought it limited the shot completly, as in not being able to spray over what they were rated for.
but how much can a plate system spray??? i was told a plate couldnt spray more than a 150 shot
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
