Positive displacement
Old Jul 20, 2004 | 01:34 AM
puckboss3's Avatar
Car: 1984 Camaro Z28
Engine: base crate 350, new GM
quick question... i was thinking of getting a supercharger. does somebody make a positive displacement supercharger for a carbureted third gen? And if so, do they make one that fits under a stock hood?
thanx
Old Jul 20, 2004 | 01:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You mean like a roots? A carburetor alone barely fits under a stock hood.
Old Jul 20, 2004 | 02:01 AM
puckboss3's Avatar
i really dont know much about superchargers. i was just wondering if there was any kits that would fit under a stock hood made by any brand (not necessarily roots) for a p.d. blower
Old Jul 20, 2004 | 02:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably not in positive displacement, about the only thing that would fit under the hood would be a centrifugal.
Old Jul 20, 2004 | 08:40 AM
nightrider87's Avatar
The small 144 holley/B&M blowers will fit under a cowl hood on our cars.
Old Jul 20, 2004 | 12:40 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Well a positive displacement is a roots type supercharger. It's made so theres an inlet and outlet and the design is setup so the boost can not escape (easily). So everytime the blower turns it's putting out a certain amount of air.
Try using the search there are a bunch of members using the weiand type setup with serpentine with a small cowl.
https://www.thirdgen.org/techbb2/sho...hreadid=215163
https://www.thirdgen.org/techbb2/sho...hreadid=129019
Old Jul 20, 2004 | 02:55 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Are not screw type chargers considered positive displacement? you could do the twin M90 setup under the hood.
Old Jul 20, 2004 | 02:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Would that be blow-through then?
Old Jul 21, 2004 | 12:27 PM
Engine: 383 SBC
Yes, twin screw types are positive displacement also. But from what I've read it would be a pita in the change an eaton type to make it suitable for a carb to sit on it. I guess he could always just run them before the carb. There's a member on the board somewhere that was running twins on a motor. I don't think it was in a 3rd gen though. He had them mounted on brackets over the valve cover areas. Basically going that setup would take some extra modification, but would be very neat once done.
Anyways whats the specs on the motor you're planning on adding a SC to?
Old Jul 22, 2004 | 02:02 AM
puckboss3's Avatar
i already have a 350 with a cowl hood. The engine is pretty much stock. i bought if from gm brand new. i don't currently have it in the car yet. about a week for that. but the engine is just the stock 250 h.p. engine.
Old Jul 26, 2004 | 12:00 PM
Engine: 383 SBC
On a stock 350 I would probably consider just a simple wieand bolt on setup. Like under the tech articles if you want a positive displacement. There's not really much need to go all crazy with it (like dual eatons) when you can only handle 4-6 lbs or so.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
