4/7 cam swap
Old Feb 13, 2005 | 05:22 PM
Jack G Jr's Avatar
4/7 cam swap
Hey fellas read an article about a new cam that Lunati is putting out.It swithes the firing order between #4 & #7 suppose to make a little more hp.Has anyone else tried this or even heard of it before?Thanks
Old Feb 13, 2005 | 07:10 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I have herd of it was going to have cam motion grind a cam with the swap thay said it would not make any more power unless I spun the motor over 8000rpm so I didnt do it
Old Feb 13, 2005 | 11:33 PM
biggtime's Avatar
I have been using these cams for over 10 years in all of my chevy engines. Really, old pro stock racing technology just hitting the mainstream now. whenever you can clean up the pulses in the intake it will make more power. Whether or not it's worth it on your combo is determined if you have maximised the rest of your combo.
Old Feb 14, 2005 | 12:10 AM
oil pan 4's Avatar
Car: 89 Firebird
One of the chevy mags did a 4-7 cam and standard cam on a street engine and it showed the 4-7 cam showed 1hp higher at 6500rpm.
Old Feb 15, 2005 | 06:46 PM
Jack G Jr's Avatar
Hey Biggtime thank for the reply.Could you give a little more info on the subject?I know a little more is involved than just changing your plug wires.
Old Feb 15, 2005 | 06:52 PM
biggtime's Avatar
I use a DFI so changing when the injector fires is easy for me. You will need to do that also. Other than that your done.
Old Feb 15, 2005 | 07:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Aren't all the factory thirdgen FI systems batch-fire? If so, what more would you have to do than install the cam and change the plug wires?
Old Feb 16, 2005 | 01:02 AM
BlownBird's Avatar
In short form...
This technology is intended for carborated cars. Smothing out the pulses of the engine smothes out the signal to the carb and gives a more accurate air fuel mixture.
Doesn't do much at all on a fuel injected car.
And yes, just change the plug wires.
Old Feb 17, 2005 | 02:39 AM
onebinky's Avatar
yup. All you will need to do is switch the plug wires, as stated.
Isn't the LS1 set up with the 1-8-7-3-6-5-4-2 firing order too?
Old Feb 17, 2005 | 07:56 AM
biggtime's Avatar
i think ls-1's switch 2 and 3 also.
It does help on all engines carbed or FI. It helps with crank deflection which in turn helps rate of acceleration.
Old Feb 17, 2005 | 10:14 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
I work in a machine shop and have personally done testing with 4-7 swap cams, every one showed a 20 hp gain.. all carb'd motors..
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
