Nice results from a 100 shot!
Old Sep 17, 2005 | 10:26 PM
Fmandan's Avatar
Car: 1987 Formula 350
Engine: TPI 350
I have a very stock 87 Formula 350 which has ran 14.70 -- 14.90's @ 94-95 mph. with the usual traction problems. My 60 ft times with stock type tires are usually around 2.0--2.1. The only mods are a cat back exhaust system.
I installed my NOS 5151 kit not long ago and just using the 100 shot pills and a low 875psi at the No2 guage (no bottle heater yet) I ran a 13.67 @107.9 mph. --Obviously that was traction limited performance.
Very happy with the results. --Dan
Old Sep 18, 2005 | 08:55 PM
TragicPark's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L V8 TPI
Very nice!!!! Similar to me only you ran better!! With 100 pills I went from a 2.0-2.1 60' and a 14.9-15.1 1/4 at 89 to a 1.8-1.9 60' and a 13.82 at 99mph in the 1/4. Congrats again on the numbers!!!
~Roger
Old Sep 18, 2005 | 09:03 PM
Mike-91 Formula 350's Avatar
107 will be a high 12.90 with traction!
Old Sep 18, 2005 | 11:26 PM
Fmandan's Avatar
Engine: TPI 350
tragicpark,
I'm pretty sure Formulas are quite a bit lighter than a GTA, plus I have like no options either. So the diff in gains is probably weight related. ---Or NOS gave me some mis-marked pills!
Mike,
I agree 107 is all someone needs to run 12's. In fact I use to run 12.5's in another car at 108mph.
I'm getting ready to do heads/Cam/Inake/Exhaust so with the Nitrous I'm hoping for very low 12s--high 11s.
--Dan
Old Sep 19, 2005 | 11:35 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i went 13.03 @103, so 107 could probably net more like a 12.6-7 with a great launch and traction...60's would be in the 1.5-6 range though to get there from here.
Old Sep 19, 2005 | 08:14 PM
TragicPark's Avatar
Engine: 5.7L V8 TPI
I agree about the weight, and I don't have the L98 but that's a different story!! Anywho, those numbers are very impressive and sounds like its got more in it. What does your h/c/i swap consist of?
~Roger
Old Sep 20, 2005 | 11:49 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Very nice. Slap some slicks on and hit mid 12's.
Old Sep 29, 2005 | 10:04 PM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
i have a 117 dry shot And sprayed from about the 1/8th mile on cuz i was purging it down the track (full throttle switch n first run on stret tires and bottle just installed) and i ran a 14.19 at 101..i plan on goin to the track now that i have mickey DR's on it and spray fully fown the track...didnt geta second run with a full shot cuz i raced a supercharged stang that gave me 5 and the hit ( i won) but that was the last race i could get in so no new times yet...i'll keep u posted, might even throw the 140 shot in to see how it does as well.
dave
Old Oct 5, 2005 | 12:54 AM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
My best with a 100 shot is 13.081 @ 107 with a poor 2.1 60' and MT Drag radials. not sure if I need a bigger stall or gears or both to help me get out of the hole. But the 5800' elevation dosen't help either. nice times man. My previous best was 14.33@96 When does everyone else activate their systems? mine is 3000rpm window switch. Gonna try a little biger shot this weekend just to see what it'll do.
Old Oct 16, 2005 | 02:26 AM
pretty happy with the new results cant wait for next season now
dave
Old Oct 17, 2005 | 12:37 PM
MIKE 1985's Avatar
My car goes from 12.30@109..1.8 60' to 11.19@119...1.58 60' on a 100 shot. spraying it right from the hole. Must be the 3.07 gears. I'm going to try and tune in a high 10 sec pass on a 100 shot.
Old Oct 17, 2005 | 01:18 PM
j69camz28's Avatar
I went from 12.09 @ 111.23 to 11.22 @ 118.55 on a 100hp shot this weekend.
1992rs/ss
16
Jan 28, 2016 09:58 PM
fasteddi
Sep 2, 2015 10:29 AM
Night rider327
Sep 2, 2015 04:17 AM
