How much boost can I run?
Old Oct 18, 2005 | 02:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
2 bolt, stock crank, H beams and 8:5:1 wiseco pistons. Cast L98 Heads. All studded and the TPI intake. Motor is internally balanced. We will also have 3 core intercooler.
Old Oct 18, 2005 | 05:56 PM
CrazyHawaiian's Avatar
Car: too many ...
Usually you find out how much it can handle after the motor is built. Detonation/Knock will be the sign to back it off. Gonna be some sort of compromise between the timing, your octane of gas, and whatever techniques you use to supress detonation.
Old Oct 18, 2005 | 08:16 PM
Steven89Iroc's Avatar
That's very similar to the L98 I built for my car so let me know how much boost it handles. I have to wait until winter 06 before I can install my TT kit as my car is in storage now until I'm out of the Navy.
It does depend on a lot, as he said just boost easy at first and work your way up as you tune. What is going to be creating that boost, btw?
Old Oct 18, 2005 | 08:44 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
My setup is almost exact but I have aluminum L98 heads and a little lower 8.0:1 compression. I've ran 16lbs on pump gas(93) but it was a little lean for comfort, but it had no detonation. I still need more fuel pump. I ran the 10.9@128 at 14lbs of boost. Im hoping after i put the inline pump in, i can run upper teens of boost(around 18) All i can do is turn it up slowly and watch the WB o2 and listen for detonation or the snap of the stock crank, haha
Old Oct 19, 2005 | 09:33 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Intercoolers a big one. The colder the air going in the higher pressure you can have without detonation.
Old Oct 19, 2005 | 08:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
D1 Procharger. The tranny is going Janis Transmission in Akron for a full overhaul. I talked with Vince the owner and he said I'll build it for 700 HP. Once thats done then the motor will be at the machine shop. Since we are getting custom pistons, should I see if we have to go 30 over? Would 10 or 20 over be good if that cleans it all up?
Old Oct 20, 2005 | 12:51 AM
Ideally you should only go over as much as it takes to make everything in spec. Usually that's .030 with normal-high mileage small blocks though.
700hp? Isn't that pusing it for even a built 700R4?
Old Oct 20, 2005 | 07:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I wont be pushing it that much but he said he would build it for 700 HP. Raptor has a new 700R4 capable of 700+ now. Its a stage 4
Old Oct 21, 2005 | 03:20 AM
dankhound's Avatar
Car: 91 RS
One thing to be careful about with tran ratings. Most all of the high hp autos are rated for off road. Which means the trans isn't capable of handling that power on a daily basis. Of course every builder is different. Just make sure you dont wind up with a drag racing tranny that you intend to use on a powerful street motor.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
toronto formula
Nov 10, 2015 06:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
BBSDesigns
Aug 11, 2015 07:39 PM
