Check out what happen lastnight? BOOM!
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Well I had I guess my first NO backfire!.....I hit it from about a 10mph roll and BOOM!!!!!!!!!!....I was like what the ******
THen my service engine soon lite came on .....so when I got home I looked at the code and it was a 34 which is the MAF...well when I popped the hood...heres what I found!..My whole air intake had blown up!..to pieces and yeah the wire in the MAF had been blown out too!......what would cause that?....I had been using it all night!
Nah I didnt purge.....got it but didnt.......I have the works!...window switch set at 3000...stall on the car is 3000 so that flashes to about 3000 when I mash the gas....
what would cause that? and what is it that happened? is this whats called a NO backfire? ...Im sure glad it didnt make it into the motor??....I guess?
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Cheers!
The only time that I had a backfire through the intake was when I hit the switch at too low RPM. With your window switch that is interesting. You experienced that at WOT and > 3K RPM?
Any other Damage? Any stains on the seat?
-Schultzy
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
you were too low of an rpm level or you did not have the butterflies opened up enough for the n2o to flow or you had an air leak in the air boot either of these can cause this to happen
Car: 1983 G20 Chevy
Transmission: 4L60
Maybe your fuel pressure was too low or your fuel solenoid did not open=very lean and a backfire.
My buddy blew the whole upper plenum off of his vortec 350 truck with nitrous.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I have seen alot of hondas taco there throtle body with NO back fires. Its funny cause it takes them a litte bit to figure it out.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i don't know a lot about nitrous but if you've got a 3k converter and the window switch set at 3k...would you want a window switch for a minimum speed, too? just thinking because of the fact that you're spraying at the same time that you throw the heaviest load at the motor; on launch.
I think I figured out what happen..tell me if this woulds cause this..
at the time this happen I mashed the gas and lit the tires up and instantly took my foot off the pedal...so Im thinking that I had the buterflys open up and did not have that much air going in and once I took my foot off the pedal..the butterflys closed and the Nitrous or extra gas had nowhere to go....so BOOM!!!!!!!
does that make sense?
yes and no.. if you have a wot switch and a rpm switch then when you let off the gas it shuts down instantly..... I have done this before and never had a problem.... I do ask again though, what was your bottle pressure...
bottle pressure was at about 900
when you say about 900 was it on the low side of 900? and what kind os systme are you running?? nx, nos, nitrous works??? I have been in your shoes before and it was a problem with bottle pressure, "which turned out to be a faulty guage" I blew mine off 3 times in one night....
I have NX...all the way....everything NX....all the goodies!..as far as low or high..I couldnt tell ya...Ive hit it as low as 300 and never had that problem...the more and more I think about it....I have come to the conclusion that it blew because the NO/gas had nowhere to go once I took my foot off the pedal even if everything was shut off......I guess!.....I'll find out once I get it all back together...Im just waiting to buy a MAF sensor....
anyone got an extra?
I had a similar thing happend to my Vett a long time ago. I turned on teh gas, the car was running like crap. I shut the bottle off adn later turned it back on with no problem,......Until I hit the throttle. KABOOM! My nitrous soleniond was leaking. I warped one head and burned 2 valves. I was using a NOS kit at the time. I now have a NX kit.
Car: 2001 SS
Engine: bolt on LS1
Did your buddy blow it up at the Evadale track?
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i have a dual snorkel setup i could sell you if you don't have a replacement yet. no MAF though. that thing got shredded.
Car: 1983 G20 Chevy
Transmission: 4L60
He put a marine intake on it, so it won't be a problem now.
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
Well there is a big problem with using N20 on a maf system because the n20 nozzle is in the air intake tube, witch is where your Maf sensor is at. The maf has a little filliment like a normal house light bulb that glows red hot and the fresh air that your enigne takes in cools that red hot filliment and the computer messures how long it take to reheat the filliment and then uses that to mesure how much air is entering your engine. My gess is that you had some sort of blockage before your TB and the n20 could not go into your engine and got all the way up to that little hot filliment and caused that bang. I might be wrong about this thoe but its just my thought lol.
db057
Aug 11, 2015 10:11 PM
