What nitrous company did you go with?
Old Feb 2, 2006 | 11:30 AM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
I'm just planning ahead for the future. I'm gonna do a Z28 or RS convertion to my car (sport coupe riht now), paint it, do rearend gears, then Nitrous. I was wanting to know which is best to go with.
Old Feb 2, 2006 | 07:35 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Don't go with Zex.
Their tech line is horrible and unless you have a fart-can muffler and a huge wing, they don't care about you.
Old Feb 2, 2006 | 08:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i would run all NX components. Their nitrous shots are rated for rear wheel HP gains not at the engine. Also typically their solenoids are bigger for each kit purchased.
Old Feb 2, 2006 | 10:05 PM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Yeah i had alot of success with NX.
Old Feb 2, 2006 | 11:18 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
i have run a few NOS systems ,but now i'm running nx.
Old Feb 3, 2006 | 04:31 AM
83 Crossfire TA's Avatar
NX here... if you can get past the fact that everythign they make uses massive solinoids I think it's one of the better choices out there.
Old Feb 3, 2006 | 08:57 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Used both NOS and NX. NX's quality and parts are above and beyond what you get with NOS.
Old Feb 3, 2006 | 08:41 PM
Raiden's Avatar
I agree! I've uses NOS and NX. NX is the best quality hands down!
Old Feb 13, 2006 | 07:25 PM
NOSFEDGTA's Avatar
I ahve used many dif types of systems. NX is by far the best out there in my opinion. Thats one of the reasons I became a dealer for them. They have some of the best noids out there, they have lifetime warranty on the noids, you get a light weight race hose for a feed line also.
Let me know if I can help you with a kit...
Old Feb 15, 2006 | 02:12 AM
TMoNeE's Avatar
Car: 87 Z28
I have a TNT F1 kit... great quality, I love it.
Old Feb 15, 2006 | 11:35 AM
LETZ RUN's Avatar
Car: 1986 ****** Camaro
Engine: 355
Transmission: th350
Axle/Gears: 3.42 10 bolt - temporary
NX or Cold Fusion if you need a good price on either of them let me know
Old Feb 15, 2006 | 03:52 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
does NX make a kit for the tpi?
does it have a plate like the NOS kit?
Old Feb 15, 2006 | 07:28 PM
NOSFEDGTA's Avatar
NX uses a single nozzle system that goes into the intake elbow about 4-6in infront of the throttlebody. It si jsut as effective and better than the nos plate. On my old nos plate I always had a lean plug on 1 and 3. it was spraying past the intake runner openings.
Old Apr 13, 2007 | 09:14 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Re: What nitrous company did you go with?
Soooooo, who's got the better price on the TBI kit? I'm currently located in GA too.
Old Apr 13, 2007 | 10:57 PM
EvilCartman's Avatar
Car: '82 Z28
What if there isn't an intake tube and just a filter attached directly to the throttle body? SOL at that point besides the plate?
Old Apr 14, 2007 | 05:02 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
I vote NX or NOS, NX seems to be pulling away at this point though. I have a NOS direct port with an NX hitman plate on my 2 stage, though i am thinking about changing my solenoids out for NX ones, we'll see how it works out. And on the subject of plate vs nozzle, i like the plate better, more consistant in my experiences, if you have problems going lean on the front cyl, either put bigger fuel jets in or run a slightly lower bottle pressure. I had most luck at right around 975 psi on my plate system.
Old Apr 15, 2007 | 10:57 AM
BadZSS06's Avatar
Car: 2006 SS 2.0 Cobalt\88 383 Camaro
Engine: 383 Afr 195, 850 cfm hp
Transmission: Dynamic Racing 700r4
Axle/Gears: 9in Ford 4.11 Detroit locker
I went with nos but i had alot of trouble with there solenoids. So i bought aftermarket solenoids. Nos knows there solenoids could be better because they sell upgrades for them. I've put a compucar kit on my friends mustang and two NX kits one on a mustang and another on an EVO. Haven't had any trouble with any of those.
Old Apr 28, 2007 | 08:35 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Anyone try the edelbrock setup? It is dirt cheap and pretty much ready to go for my carb. I am sure it outsourced it's kit from NX or NOS or one of those companies.
Old Apr 29, 2007 | 08:01 AM
Car: 91 z28
the NX hitman kit is about the same price and has proven itself on durability, i would recommend that over the edelbrock, mainly because no one i know has used one, and i dont know many that have.
Old Apr 29, 2007 | 03:15 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
thinking about adding nitrous to my list of goodies soon to be purchased. whats the best for cheapest rate these days and prices? its going on my 89 lo3 305 rs nearly stocker but goodies list includes lt1 cam, hedmen shorties and y pipe, cold air intake, and tuning. any suggestions? someone who has done this same motor>>??
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
80smetalfan
Sep 22, 2015 02:55 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
