Who has a turbo on there thirdgen?
Old Feb 18, 2006 | 02:58 AM
icebird_1981's Avatar
i was just wondering how many people on here have a turboed thirdgen? Any pics? also how is it with the gas?
Old Feb 18, 2006 | 04:01 AM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
why not check the power adder forum????
Old Feb 18, 2006 | 06:45 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Here is mine. I still have a lot of cleaning up to do. ie. coat the headers, clean the engine bay, get my heat shield back from the coaters, clean the under side of the car, replace air dam, struts, rear end, slicks, etc... It will run before spring though.
New brake system is fall's project.
From what I understand, as long as you stay outa the boost on a daily basis, the gas mileage is pretty good.
Old Feb 18, 2006 | 07:02 AM
Mr. TurboTA's Avatar
Mine!
But it came from Pontiac that way!
George
Old Feb 18, 2006 | 11:33 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
This really has nothing to do with appearance and detailing, so to the Power Adder boards it goes
Old Feb 18, 2006 | 05:12 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
I've got two of 'em.
I've gotten 20mpg on a trip this fall. But I wouldn't run boost if you are concerned about 'how it does on gas.'
Old Feb 18, 2006 | 05:43 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Here's mine :
Looking good Eric, how's it coming along?
Steve
Old Feb 18, 2006 | 05:51 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Originally posted by TTA850
Here's mine :
Steve
Coming along well. The rear end is on order. Strange Dana 60 for the rear. Than I have to do my struts. Waiting for the headers, crossover and turbo shield from the coaters. Than fuel lines and fuel pump, button up some small things, clean everything back the way it was and done. Well that is if I don't run into any bugs when I turn the key. It will be done before spring.
Old Feb 19, 2006 | 09:34 PM
Steven89Iroc's Avatar
I will with this kit and my Camaro in the sig when I get it back.
Unfortunately it's all still like the pictures. Separate that is.
I do have a bigger IC for it now though, and the valve covers are on, heh.
I'm getting REALLY antsy now. I'm honestly getting tired of my use-to-be 11-second 4 banger.
Attached Thumbnails Who has a turbo on there thirdgen?-camaro-tt-kit-complete.jpg
Old Feb 20, 2006 | 09:50 PM
Syn's Avatar
Syn
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
89j i love the iroc way more then the Z
Old Feb 20, 2006 | 11:38 PM
KillerZ302's Avatar
Car: 1988 Iroc-Z and 1985 Z28
Engine: Mild TT 355 and Built 383 Superchar
Transmission: Manual
Well, count me in too. Gets about 12 miles to a gallon of 100LL mixed with 93 octane when I am really pushing it.
Comming real soon.... new twin 2.5 inlet carb hat, which will eliminate the T in my piping. Now I need to buy another bov. Still is making awesome power though.
Still thinking of what to do with the LS1.....?
Old Feb 20, 2006 | 11:57 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Old Feb 21, 2006 | 12:05 AM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
^^^^ Its that a intercooled BBS setup? Looks bloody nice.
Heres mine. Custom RHD headers originally supplied by Ed over at BBS and then modified slightly to fit by myself.
Needs an intercooler
Old Feb 21, 2006 | 12:15 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
I used the BBS Turbo Header....the rest I made up myself. Yes it is intercooled.
Ray
Old Feb 21, 2006 | 07:15 PM
Sorry to get off topic a bit, but when you set your radiator back for the IC, did you just off-set the top and angle it back? or did you move the bottom back as well?
I really like how your setup turned out dude.
Old Feb 21, 2006 | 09:51 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I had to move the bottom back as well. I had to notch the lower rad. mount and moved it as far back as possible. The bottom is about 1/8" from the steering box.
I'm in the process of installing a BMR K-member, A-Arms, Coil Overs, and Wilwood Brakes. I also had a lower compression motor built with all fordged internals, custom grind Cam, with Dart Heads and a Holley Stealth Ram intake w/58mm Throttle Body
Ray
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
PestilenceIV
Aug 20, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
