Need help deciding on an engine for the turbo project...
Old Sep 24, 2000 | 04:23 PM
89ProchargedROC's Avatar
Well, i have decided to not go the 383 route because of the rpm limit and the rod-stroke ratio. Also, a 6.0 rod with a 383=expensive pistons. So i have decided on either a 406 or a 377. Now just to let you know, i am getting a bow tie block pretty cheap so boring and that stuff isn't a problem. I have it narrowed down to three choices:
- 406 with either 5.7 or 6.0 rods
- 377 using a destroked 400 block
- 377 using a big bore/350 block combo
Could someone tell me the benefits of each. To let you know i am looking for nine's, period. And a maximum redline of 7000 with peak power around 6500. Thanks for all your help.
Old Sep 24, 2000 | 04:29 PM
superiroc's Avatar
I would use a 355 but if you already have the bowtie block go with it. Give speedway a call and talk to bill he can probabily give you the best advice on what engine to use. I assume this is a street car. I'am going with the 355 because its easy and cheap for me and will make power to put me in the 9s with ease.
Old Sep 24, 2000 | 10:48 PM
Guido's Avatar
Car: 2000 Trans Am
Well, I have done lots of research and one thing I learned is that the long rod is always better.
377 are super for revving but if you want to see 7k as your limit, than a 406 is going to suit you fine. youll have more torque in the range you want to be making power. As far as starting earlier as compared to a 377. Of course the 377 will wrap up quick Im sure.
These are my opinions and why I ended up with a 406 instead of a 377.
Im sure others will have different input. Im far from being an expert engine builder but know enough to be dangerous.
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
[This message has been edited by Guido (edited September 24, 2000).]
Old Sep 25, 2000 | 01:48 AM
GMI FAST's Avatar
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
http://www.mfba.org
Old Sep 25, 2000 | 07:19 PM
Twin Turbo 358's Avatar
i'll let everyone know how my TT 358ci turns out--i should be firing it up this weekend or next. i've just got some last minute fittings/connections to get. previously it was a twin turbo 350ci but with stock TPI intake, mild 440/465 lift cam, stock replacement heads with big valves. it made 465 rwhp in this configuration with no intercooler and on 93 octane. shooting for 550+ rwhp this time around with a miniram intake, DFI w/ variable injector controller, custom grind cam, Dart Sportsman II heads and other goodies. as soon as i figure out how to do the intercooler, i can get a 3 bar map sensor and crank the boost up a little higher for some serious power...
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
Old Sep 25, 2000 | 10:12 PM
superiroc's Avatar
keep us posted twin turbo
Old Sep 26, 2000 | 08:18 AM
I think i am going to give Bill a call at Speedway. In his 8 second street vette, he used all bow tie stuff, except for rods/crank, and made a very fast motor. this would be great for me since i can get mass discount on GM Performance parts. i'll keep everyone posted on what i am doing. Just to give a rough estimate, this car wont be done for about 2-3 year.
Old Sep 26, 2000 | 02:00 PM
superiroc's Avatar
That same vette know has a 1600hp 410 SB with one turbo and he says will go 7s at bristal and he claims he drives it on the street alot WOW.
gta90
Sep 15, 2015 04:00 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
