It's alive! (but I killed it real quick)
Old 10-09-2000, 11:16 PM
Supporter/Moderator
askulte's Avatar
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Hey guys,
I finally got the Z back on the road again! (3 month long Street Twin clutch install). I took it to the track about 12 hours after it was running with some interesting results (13.4@113.9) This is with a super conservative timing and fuel map. I was still getting 20 deg of knock retard the last time I checked the DFI, even with a base timing of 10 deg with 20deg max dialed onto the timing map. I'm ready to unplug the knock sensor (retarding the timing doesn't reduce the knock) and see what happens.
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
http://www.skulte.com
Old 10-10-2000, 12:08 AM
GMI FAST's Avatar
Good luck!
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
http://www.mfba.org
Old 10-10-2000, 12:30 AM
Brett's Avatar
How'd you finally make out with the Street Twin? Happy with it?
1991 RS LT1
every imaginable bolt-on, ungodly LT1 355, and 12 pounds of intercooled boost on it's way in '01
2000 C5 Coupe
black/black 6-spd, optional polished rims, first run 13.056 @ 109.52 stock
"So what DOES the back of a Mustang look like?"
Old 10-10-2000, 09:27 PM
Supporter/Moderator
askulte's Avatar
Car: '89 Z28tt
I'm happy with it. The cost is obscene, but it's the only game out there for the OEM T56. It was very on/off for the first 50 miles, and got more progressive. The T56 with a 3.08 rear doesn't help the big time bog off the line. It felt like a regular T56 clutch once it was broken in, probably due to the same T56 pressure plate being used. I guess we should continue this in drivetrains if we want to be proper
A.
Old 10-12-2000, 09:01 PM
Twin Turbo 358's Avatar
Andris, if all goes well this weekend, mine should be alive too after a long hibernation! (keeping fingers crossed)
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
Old 10-13-2000, 10:23 AM
RCR
RCR's Avatar
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Andris,
If you should happen to find something with your timing problem, could you shoot it my way. I've recently noticed I'm getting a lot of retard from my DFI. I thought I fixed it by replacing the knock sensor, but it was back the next day. Why, I have no idea. If I find anything, I'll let you know.
Bob
Old 12-17-2000, 11:06 PM
IrocZ335's Avatar
Sorry I am a little late in posting this but I want to wish you good luck. Hopefully I can get started on my ATI procharged 335 project soon. As soon as you take her out again get her and get any bugs out get her dynoed and post the results. I am very curious. I always like to see people who like to do something a little different. Wish I had the $ to take your route. Saw your intercooler pics. Question: Have you had any problems with the nose of the car with the center piece cut out for the intercooler.
1986 Iroc Z 305
3.23 posi-rear
ported mass-air
custom ram-air
removed air pump, converter, straight pipe no muffler
0-60 5.5 sec
1/4 mile at 102mph
est 285hp
fiberglass hood
$2000 Alpine stereo hit 135 in spl comp.
Old 12-17-2000, 11:07 PM
IrocZ335's Avatar
1986 Iroc Z 305
3.23 posi-rear
ported mass-air
custom ram-air
0-60 5.5 sec
1/4 mile at 102mph
est 285hp
fiberglass hood
Pac J
05-17-2020 10:44 AM
mattcanty
10-12-2015 11:08 AM
racereese
10-03-2015 03:46 PM
meeklay812
10-01-2015 03:46 PM
Galaxie500XL
10-01-2015 01:05 PM
Quick Reply: It's alive! (but I killed it real quick)
