2 questions about the vortech install
Old Feb 3, 2001 | 06:00 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
1) Do you think I should swap to serpentine first, then do the install? Or do it all at once?
2) I deleted my a/c a while ago, which was easy on the multi-belt system. I just ordered the GM part# #10055890 for $60. It's a pulley and I believe a breacket too. I thought it was cheaper, but, is that all I need to do a/c delete to a serpentine system???
3) Oh yeah, third question, is there anything wrong w/ using a procharger inline pump w/ my Vortech kit. Will it support 15lbs bos tor just 10???? t
Thanks for you help.
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph (Naturally Aspirated): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB> PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old Feb 3, 2001 | 06:53 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I think you'd be better off doing it all at once because the Vortech does not use the stock driver's side serpentine bracket.
Don't know the answer but I don't believe you would get two parts with one part number.
Why not? I use a Vortech T-rex pump with my ProCharger.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Feb 7, 2001 | 12:35 PM
Car: 1987 GTA
Does anybody know the answer to question 2?
Old Feb 7, 2001 | 01:37 PM
Willie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Justin 87 GTA:
Does anybody know the answer to question 2?</font>
Justin, call your local GM parts department and give them the part number. They should be able to tell you exactly what it is.
Willie
Old Feb 7, 2001 | 01:46 PM
Car: 1987 GTA
I already ordered it, and the guy couldn't tell me for sure what it came with. I know I need it, but do I need anything else? I looked at the schematics also, and couldn't determine exactly what it came with. It is listed as a pulley, but I think they give you the bracket too. Does anybody know for sure?
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB&gt; PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old Feb 8, 2001 | 01:53 AM
Omar's Avatar
Do you already have the big bracket that houses the AC compressor and the smog pump? If so, then that AC delete pulley is all you need. If you ever want to ditch your smog pump as well, 10186167 is for the smog pump delete pulley.
1989 IROC-Z 5.7L
Old Feb 8, 2001 | 09:01 AM
Guido's Avatar
Car: 2000 Trans Am
Look where the AC is supposed to be on the passenger side. That bracket with a pulley on it bolts in place. Its 1 part number. I dont remember what that number is off the top of my head though. LOL
I bought it through GM about a year ago.
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
Cluelessness: There are no stupid questions, but there are a lot of inquisitive idiots.
Old Feb 8, 2001 | 11:12 AM
Car: 1987 GTA
I see that. Now what's that right next to it on the right? is that a tensioner? Is that standard on all serp setups? Do you have any other pics of the install that may make it easier for me? Thanks a lot -Justin
Old Feb 8, 2001 | 12:59 PM
JeffT's Avatar
Car: 1991 Z28
Justin, yes that is the factory tensioner and it is standard on the serp. set up.
The AC/Smog pump bracket is one piece and it attaches to the front of the block with 2 bolts down by the balancer and I believe two studs up on the head. The smog pump/ac delete will bolt to this bracket. On the other side you will have the Vortech bracket and it will support the SC, Alt. and PS pump per the Vortech installation instructions. This should be a pretty straight forward swap.
Old Feb 8, 2001 | 01:38 PM
Car: 1987 GTA
thanks. that makes it a lot easier to understand. Look like it will be pretty simple. thanks -Justin
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
