How much nitrous is too much?
Old Mar 19, 2001 | 03:31 PM
MouseCamaro305's Avatar
l've got a 1990 IROC-Z with a TPI 305 it's basically stock (68,000 miles) l'm currently running 100 horses worth of nitrous through it, it does awesome but l was wondering if l could squeeze out just 50 more with the stock settings, should l retard the timing, run more octane, wait to get an ignition system and adequate fuel system? has anyone else ever done this?
thanks very much
Old Mar 19, 2001 | 07:11 PM
Kwiksilverz28's Avatar
I wouldn't try it unless you have the resources in case you roast it. I helped put a 250 on a stock 350 (against my suggestions) in an older nova, and I drove it. Couple of good runs in the 13's, then the COOLEST motor loss I have ever heard. Let's just say ventilated block... Stay with 100 and work the combo till you can build a NOS motor
Old Mar 20, 2001 | 06:12 AM
Nitro Don's Avatar
Go ahead and run the 150.Myself and a couple of other guys have been running 150 jets for a long time in our 305's.Leave the timming stock at 6 degrees BTDC,you'll be fine.
Ive ran 82 nitrous/65 fuel,which is about 175 hp jets in my completly stock "BOTTOM"
305 with no ill effects.
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
TCI shift kit
Vette servo
B&M 3-4 upshift kit
TCI Trans Rebuild
2800 stall 9.5" TC
Nitto Drag radials
FUTURE MODS:
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
Old Mar 20, 2001 | 01:57 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
I'm with nitro don. My first time I ran 175 hp jets. But I didn't care and it was on the stock motor that has no compression right. The only thing I did to make sure it wouldn't blow was run a digital 6 to retard the timing when I hit the button and checked my plugs after every pass. 12.84 on that 86 305 tpi.
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old Mar 20, 2001 | 08:58 PM
thanks a lot for the responses guys, I'll have to give it a shot and hope I don't blow up the motor
Old Mar 20, 2001 | 09:07 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
You're running too much nitrous if:
- you win the race AND blow up your engine
- hmmm
That's about it.. As for your ride, I concur with the other posts.. I don't think 150 will harm your engine at all, as long as you don't hit it too early. With a shot that "large" on a 305, I'd be above 2500-3000 rpm before laying into the nitrous.
My bigger concern would be your transmission.. If it's a 700r4, especially going from the 1 - 2 shift on the spray. Since your car is a 90, it has a better tranny than my 86 did, so you might get away with it, especially with only 68k miles.
Have fun!
Steve
Old Mar 20, 2001 | 10:41 PM
Bob Wooten's Avatar
If you have a good mix & your fuel pressure is haning in there, too much is when you start to lift the heads or hear someone @ the door (knocking). if you run it lean, say good night francis.
personally, if were me & this is the commuter, keep it simple & small (100/125) if this is the toy, letter wail! once you have learned a ton on the N2O & blow it to the sky, it is time for a new motor. start on the small side. do a TON of plug cuts & remember to keep them "almost wet" learn what this stuff will do. it is pretty fantastic stuff.
there is a guy here in SD, that runs a 72 or 73 Firbird that has a low compression (8:1, 9:1) 468 BBC. he has nothing special in the car but 2 fantastic fuel systems & a ton of juice. he is running 3 systems & is in the low 9's. this is the 3rd car that he has dont this formula on (65 chevelle, in the high 8's/low 9's, & Ponty Monty white monte carlo w/BB Pontiac in it (has been in Car Craft). same formula, same results.
FWIW
BW
Bob Wooten
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Mar 21, 2001 | 12:37 AM
89ProchargedROC's Avatar
personally i think you are running too much nitrous when:
your nitrous system has more horsepower than your motor....
but BUILT NITROUS MOTORS are like that. Have a few friends with big juice and built nitrous motors.
they run mid to low 12s on motor and mid to low 9s on spray...
Old Mar 21, 2001 | 06:49 AM
LottaBallsCamaro's Avatar
What about a LO3? Do yall thnk it could handle a 150hp shot?
We are the futrue, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Mar 21, 2001 | 12:02 PM
Bob Wooten's Avatar
i find it so incredible what can come out of a bottle. the cars that run 12's on the motor & 9's on the bottle blow me away.
BW
Bob Wooten
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
